Results 1 to 3 of 3
Thread: Alpine TME-M740BT question
    Feb 2008
    Hey guys,
    I want to get one of these so I can have nav in the car.
    I don't care to swap out the factory HK headunit in my Outback, but I would like the bluetooth to work.
    How does the bluetooth wiring work? Since my car uses an external amp stock (with line-level-inputs), how would you all suggest I wire it up?
    There's a "mute" output it looks like from the screen.
    Ideas?
    Thanks!
    Jan 2008
    usually, the bluetooth setup in a factory system is in the radio, so removing it will loose the bluetooth feature.
    you could get a differnt nav unit with navigation and bluetooth, or you could setup a carputer with bluetooth...
    Feb 2008
    Hmm,
    I'm trying to add bluetooth though, not remove it.
    The 740BT is bluetooth ready. So I can pair my phone with the screen. Trouble is, outputting the audio from my phone call. The screen has a "mute" line, or so it seems, and it also has L&R outputs.
    My car, a 2009 Subaru Outback 2.5XT, has a Harmon Kardon stock stereo that uses an external amp (which is fed by line-level input).
    Would it be reasonable to send the "mute" signal to the headunit (simply T it into the stock mute wire from the steering wheel control), and then plug the L/R wires into the line-inputs on the amp?
    Or would that not work?
    I don't intend to remove the OEM radio, simply add this screen and a NAV unit to it.
    Will it work?
  1. Ipod / usb recognition question
    By psychotic in forum Newbie
    Last Post: 05-17-2008, 06:10 AM
  2. From Monsoon to Alpine CDA-9885 - A Bitter Ordeal
    By Eugene08 in forum Car Audio
    Last Post: 02-24-2008, 12:50 AM
  3. Alpine digital audio setup. . maybe.
    By Crazystick in forum Car Audio
    Last Post: 11-26-2006, 10:07 AM
  4. Hardware Review: Car2PC Alpine MBUS review
    By MatrixPC in forum The Review Palace
    Last Post: 06-02-2006, 07:39 AM
  5. MP3 & Alpine combo question...
    By Tripp in forum General Hardware Discussion
    Last Post: 03-31-2001, 11:38 AM
