Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Old 619 screen - Converted to LED. PICTURES included!
    Apr 2007
    My lilliput 619 over the years has started to dim quite a bit. It went to the point where it was pratically unreadable in all conditions during the day.
    So I decided to upgrade. I took out the existing cathode and here's what it looks like. The picture makes the cathode look really bright but it's not! PARTS of the darn thing is burned OUT! I guess after years and years of abuse from being in the extreme conditions of the car, it just couldn't withstand it any longer.
    I got this LEDs strip from superbrightled. It is about the same width as our LCD panel.
    http://superbrightleds.com/specs/FLS.htm
    About 1200 mcd/2, should be a huge improvement.
    I removed everything, then started cutting holes in the plastic frame and the white liner. The holes are just big enough to have the LED part of the strip to stick in. This will also allow the LED to remain flush and allow me to utilize the metal frame to secure the led in place without any glue or tape.
    I didnt take any before pictures but here's the after.
    Without LCD.
    Uniform light? or Bleeds:
    As you can see the light is slightly not uniform. However, it's very minimal. You'll barely notice it during normal operations at night or during the day. You only see it when the screen is all black and it's not even all that bad!
    With LCD.
    Talk about a significant improvement!
    Now, to adjust the brightness for night viewing. It's will be just too bright at night. There's 2 options to adjust the brightness of LEDS. First is to lower the voltage. Which will do fine in most cases but there's a limit to how low you can go. If you go out of the operating voltage, you will get nothing. The second option is to use a controller and drive the led with pulse. You might even increase the brightness in the process. http://www.ledsmagazine.com/news/5/5/11.
    They sell controllers to do this or you may create your own custom microcontroller device (which I may just do) but that will be later.
    What do ya think?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Very interested in how this will perform in the sun. Ive been meaning to do an LED upgrade project too.
    Apr 2007
    The screen performs tremendously better during the day. It's pretty cloudy today, so I can't really compare it to a really sunny day. I will put it in my car as soon as I have it all together. My compartment needs a little repair but I will get to it as soon as I have time.
    - Typical glare from touchscreen unit. Will bond an anti glare to the touch when I get my hands on anti glare stuff.
    All in all, I say there's a significant improvement over the old cathodes. I says this might be even better than the newer Lilliput LED touchscreen because I potentially have an limitless dimming potential and full brightness without wash out colors. ( I just remember using the lilliput leds at night and it's blinding, even with the settings lowered. My eyes weren't the same after that). And it seems to have similar brightness during the day. However, I don't currently have a Lilliput led on hand to compare (doing it via memory).
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Nice. That looks like a good improvement. So is it the 30 LED strip? 12V seems like an easy replacement.
    Apr 2007
    I used the 30 LED strip with cool white. 1200 mcd/2! However, I was only able to put 21 LED in there. The LED strip can be cut every 3-LED segments.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Wow, Im having trouble visualizing just 21 leds being brighter than the stock CCFL tube (which is blinding). Is it really that bad at night-time? I have the CCFL EBY701 which has the same lcd panel as the 619 and I find the brightness is just perfect. Not too bright for night, but bright enough for the daytime. My plan was to have two sets of led strips, one on the top, one on the bottom. The top strip would always be on and the bottom strip would be controlled by a photo sensor, such that the bottom strip only turns on when it's bright out.
    Apr 2007
    It really depends. My 619 is really old. 5-6 years?
    The EBY701 has a rating of 400 mcd/2. That's pretty bright. I believe mines had less. And Cathodes degrade overtime, whereas LED does not.
    So after 5-6 years my LCD backlit is pretty much toast.
    LEDS has tremendous benefits over Cathodes too. It takes less LED to produce the same amount of brightness. It uses less wattage also. So 21 LEDs might pretty much be overkill in a production environment but considering my LCD is made for cathodes, it should be plenty.
    I came across a few 629 LED units a while back ago. They are only rated for 300mcd/2 and IMO these suckers were too bright at night (at medium setting, the lower settings were just awful when it comes to PQ). Maybe the 629 LED adjusted the brightness artificially and kept the LED operating at max brightness. Which explains the washed out PQ on Max Settings. Max settings probably just allowed the LCD to pass more light through, all while sacrificing color.
    This is a 20 dollar solution to replacing your backlit vs buying a new unit with all the bells and whistles for 300. Or Buying a LCD with Cathode unit for 150.
    Mar 2004
    Florence Yall, BFKY
    Mine might be older. LOL The only thing holding me back is I have the inverter powered off the dash lights at night. It ranges from 7V to 10V. The LEDs probably cut out under 9V. That could be a problem. When I do MOSFET PWMs they tend to get slow on the low end too and the flicker would drive me nuts.
    Apr 2006
    Sydney, Australia
    Great Mod!
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I think I will have to do this to mine since it is about 5-6 years old, but mine has never really been readable in sunlight. Did you mean 1200mcd instead of lumens? 1200lumes is like a 100W incandescent bulb, I think you would go blind starring at that sucker. Nice idea.
  1. (need help fast) Are the 619 2008's LED backlit also?
    By Phatsacks in forum LCD/Display
    Last Post: 04-14-2008, 02:53 PM
  2. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  3. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
