Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Transflective or not
  1. #11
    May 2005
    Quote Originally Posted by soundman98 View Post
    you are comparing different products-- there is a huge demand for transflective, or sunlight readable screens for car equipment manufacturers, but those are special screens, that might not be vga compatible, and the manufacturers are order large quantites of them.
    there is very little demand for sunlight readable automotive sunlight readable vga screens. even if everyone on carputer forums had to go buy a new monitor tomorrow, we would still probably only equal half the demand (maybe less) of what the larger manufacturers use in a year.
    I don't know the specifics of the panels that the auto makers use, but I would suspect that it is very similar to the ones we use. My guess is that the electronics are different to accept a different input but that's all. Who knows. Not me
    I would assume that a 640x480 panel is driven the same way regardless of what board is attached to the back of it.
  2. #12
    Jul 2009
    B.C., Canada
    Consider LED backlit. Better than standard, but cheaper than transflective.
  3. #13
    May 2005
    Quote Originally Posted by Tical84 View Post
    But the touchscreen overlay still becomes a mirror when the sun hits it.
    I can see that working ok if it is mounted down low near the gear selector, but up higher on the dash it can be very dangerous.
  4. #14
    Jan 2008
    I have a 629 led backlit, and it does help, but as sebberry said, it is the touchscreen overlay that is causing the glare. From what I have read, having the screen modified to a transflective is the best ballance between light transmission and sunlight readability.
    There are other overlays that you can apply yourself, but most will affect the light output, or color of the screen
  5. #15
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Whether it's worth it or not comes down to the user. I have a standard EBY701, probably one of the cheapest screens available, and it is completely visible 99% of the time. For the 1% of the time I can't see it (direct, very bright sun), I just put my hand over the screen and bam, problem solved.
    LED backlight doesnt guarantee that the screen is better than standard ccfl. I looked at the specs for the Lilliput screens and the led version (with the Innolux panel) is actually less bright than the ccfl version with the Hitachi panel.
  6. #16
    Nov 2009
    Well i ordered the 7 inch transflective. I'll let you know how it goes.
    If you don't go touch screen do the sunlight and viewability issues still exist.
  1. NEC 8.4" Transflective Solution - Custom Kit
    By thermoptic in forum LCD/Display
    Last Post: 12-11-2010, 12:02 AM
  2. CarTFT Transflective vs LinItx Transflective
    By Triad.: in forum LCD/Display
    Last Post: 06-28-2008, 03:41 AM
  3. Transflective + WRX Bolt-In
    By infomage in forum MP3Car Products - store.mp3car.com
    Last Post: 01-24-2008, 12:05 AM
  4. Mp3Car's Transflective vs. CarTFT TMR
    By ovsims in forum LCD/Display
    Last Post: 01-05-2008, 11:16 PM
  5. FAQ: Transflective Technology
    By nameeri in forum LCD/Display
    Last Post: 06-06-2006, 11:26 PM
