Results 1 to 7 of 7
Thread: Need help wiring two headrest monitors
    Nov 2009
    Ok first off hello to everyone I new here!Ok I just bought two headrest monitors from ebay and when I recieved them they only had a s-video coming out the back of them.So I'm looking for a way to connect them by cutting the 6 pin off or mayb some sort of adapter.I've cut the one already and it has 5 wires a blue wire with a smaller wire inside a red wire with a smaller wire inside a black wire a brown wire and a wire with no cover.I see the two wires for the audio that go to the little speaker inside the casing other than that I'm completely lost!Thanx
    Oh it a MA AUDIO Model # AM-050PN/PP-C
    Elsewhere
    Quit crossposting.
    How about the Wiki?
    Nov 2009
    my bad about that. new to this!
    Newbie rickhigginshtbr's Avatar
    May 2009
    Hatboro, PA
    ...i would reattach that. If you have s-video out on your video card, run a splitter to those two. If it's composite out on a HU, use a splitter, then composite to SVid adapter.
    Nov 2009
    The cable coming out the back of the monitor I think its called and 6-pin mini din or a mbus cable.Its to feeds power and video.Thanx
    Apr 2010
    Pin out for 6 pin mini din
    Okay, I spent a lot of time with a digital multi meter to figure this one out since I couldn't find an answer on the internet or get one from MA Audio, figured I'd share the wealth. If you open up your monitor, you will see a 10 pin flat connector with red, blue, brown, and black wires. For our purposes, we will refer to the pin with the red wire as pin one.
    +12v - pin 4, shiney black wire
    12v return - ground, (there are 3 gound wires, they all go the the connector shielding)
    +video - pin 1, red wire
    vid return - ground
    +audio - pin 2, blue wire
    audio return - pin 6, black wire
    What I did was make my own connector from a PS/2 extender cable (for old school mouse or keyboard). I plugged in the female end to the monitor, and hacked off the male end. Here is the pin out for that:
    +12v - Black wire
    12v return - ground (exposed wire usually)
    +vid - Orange wire
    vid return - ground
    +audio - Yellow wire
    audio return - Red wire
    Hope this helps!
    Mar 2011
    Hey do you know what wires to splice into the factory amp? I have a 04 vw jetta 1.8t. I want to put my system in and keep the factory HU I have everything like the amp and subs and also the high to low converter I just don't know what wires to splice in to or if I should splice into the speakers ( and how would I do that) If you can get back to me that would be good. Thank you
  1. Wiring
    By ssteger in forum VaultWiki
    Last Post: 10-14-2009, 05:09 PM
  2. Replies: 42
    Last Post: 07-25-2007, 02:15 PM
  3. Finally installed my headrest monitors
    By hpric in forum Show off your project
    Last Post: 12-08-2006, 03:31 PM
  4. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  5. suggestions on headrest monitors?
    By kaotic504 in forum LCD/Display
    Last Post: 01-20-2004, 02:03 PM
