Results 1 to 3 of 3
Thread: Programming Code for Lilliput 629GL
    Dec 2007
    Mohnton, PA
    I just got my new 629GL (DVI input) and the 588998 code does not work on this model, so I was hoping someone would know how I can get into the settings to enable the Auto-on so it will power up when it receives video signal.
    Newbie _Parilla_'s Avatar
    Aug 2003
    Brazil
    Quote Originally Posted by phuz View Post
    Me too, the same 629GL DVI and 588998 nothing.
    Anyone pleaseeeeeeeeeee ???
    2008 Honda Civic LXS
    Zotac 630i
    2Gb DDR 800
    500GB
    Lilliput 629 (DVI)
    WinXp Pro (Customized)
    Holux
    M2-ATX
    3D Connection
    Centrafuse
    Aug 2003
    Brazil
    Thumbs up
    I found !!!!!!!
    Please find the instruction below to turn on 629GL-70NP with DVI when power is connected.
    1. Plug in the power. Make sure a video or VGA signal cable is connected and the video signal can be received when the monitor is turned on.
    2. Press and hold power button for 5-7 seconds, release the power button and press it again immediately to turn on the monitor. Press menu button, the factory mode should display.
    3. Press menu button to select 3rd page. Select power state mode by “> button” and change the value of setting from 0 to 2 by pressing “Vol+” button.
    4. Press menu repeatedly to save and exit.
    Thank you.
    _Parilla_
    Zotac 630i
    2Gb DDR 800
    500GB
    Lilliput 629 (DVI)
    Holux
    M2-ATX
    3D Connection
    Centrafuse
  1. Unlock Code for Sony CDX-M700R
    By blacknightwolf in forum General Hardware Discussion
    Last Post: 08-27-2007, 02:51 AM
  2. code tags.
    By Enforcer in forum Mp3car Forum Suggestions/Comments
    Last Post: 06-26-2007, 02:53 PM
  3. BR-3 VB6 Sample Source Code
    By Zharvek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-15-2007, 08:43 AM
  4. AMP 1.X Complete Source Code Release
    By aychamo in forum AMP
    Last Post: 04-12-2007, 01:18 PM
  5. Java Programming help
    By Cheekz185 in forum Off Topic
    Last Post: 02-14-2007, 02:06 PM
