Results 1 to 6 of 6
Thread: Datalux
    Nov 2001
    Sikeston, MO
    Datalux
    Is $120 for a Datalux without touchscreen a good price? This includes shipping. I bought it, and think I got a good deal. What do you guys think? IT Is an LMV10R 10.4".
    ---=== NOT EVERYONE CAN BE A MOBILEGIGOLO ===---
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    If it includes inverter and controller you are set, YES I think it was a good deal. I would have payed that ammount for it as well.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    That isn't bad, really. I scored one on eBay about 2 weeks ago for $92 shipped but it had lines in the screen. It turns out that the guy had the wrong resolution set on it. It worked fine! I replaced the screen with a brand new LQ10D367 anyway...just cause of the age of the unit. It's nice and bright now.
    I took a chance on it, though - could have easily been the controller and I would've had a $92 case, inverter and panel.
    - Jeff
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Angry HEY!
    I was bidding on that one and you took it from me! How rude! GRRR! I thought you should know, the guys says he hooked up a higher voltage power supply than it could take. I figured it probably burned out the inverter. Good look with it though.
    Nov 2001
    Sikeston, MO
    I took it from you??? You bid on it 4 hours before it closed. While not bidding on it the previous 4 days. Payback is hell. I bid on it with about 30 seconds left, but I had also bid on it 2 days earlier. I wouldn't say I stole it from you. If he had hooked up too much power to it, why would you bid on it, and now be upset cause you didn't get it? Doesn't make sense to me.
    Justin
    Apr 2003
    HOT Arizona
    EAASY!!!
    Easy jiggy. I thought you could tell I was just being sarcastic! (or whatever) I did want it, but only for the touchscreen panel, not anything else. I didn't want it for over $90 , there were two others that sold a week ago that had the same problem, they wouldn't power up. But they sold for $30 and $50 something.
    Good luck with it!
