Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: need some help connecting screens
  1. #11
    Jan 2008
    Quote Originally Posted by Sicarius View Post
    BTW, the mini-DIN port on the back of the MP965-D is not an s-video port. There should be a breakout cable that plugs into it which provides s-video, composite, and component connections.
    See the manual.
    so i was reding the manual and it refers to the piece that goes into the mini din port as an “S-Video to S-Video/YPbPr/Composite Video”. So that being said woulnd that make that plug an S-Video output? I ordered the two converters and they will be here some time next week i just wanted to bring that up. Please correct me if i am wrong here. also there is a little pic under the plug that is and "S" inside of a box with an arrow pointing to the right that is coming out of the box (maybe s-video out?)
  2. #12
    May 2008
    Quote Originally Posted by 2001SUBURBAN View Post
    "I meant what I said, and I said what I meant.
    An elephant's faithful, one hundred percent."
    Dr. Seuss, Horton Hatches the Egg
    OK, I'm not an elephant...
    See the manual.
    Chalk up the "S-Video to S-Video/YPbPr/Composite Video" to translation errors.
    If you have the breakout cable, then you won't need the s-video->composite adaptor as you can just use the composite out on the breakout.
    If you don't have the breakout cable... Well, then you've got an issue.
  1. Dual Display Solved - 2 programs, 2 screens
    By Nstyle in forum LCD/Display
    Last Post: 09-07-2007, 08:37 PM
  2. Headrest screens look rough and video will not show
    By jac1502 in forum LCD/Display
    Last Post: 06-10-2006, 09:38 PM
  3. Replies: 9
    Last Post: 06-15-2004, 08:09 AM
  4. Multiple Screens? Larger Screens?
    By Atom_Bomb in forum LCD/Display
    Last Post: 03-31-2004, 06:24 PM
  5. 2 screens...possibly some other stuff..
    By SuperMatty in forum Classified Archive
    Last Post: 08-18-2002, 01:20 PM
