Results 1 to 10 of 18
Thread: powering the lcd - is there a "best" method?
    Aug 2005
    I notice lots of folks seem to use their power supplies for this.
    Is there any problem just using the existing wiring intended for the factory radio to power the monitor?
    Just curious why folks would use the power supplies when 12V wires are right there in the dash already.
    TIA
    Heath
    First Carputer in progress.....
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I use my power supply because I ran into issues with the monitor flickering using the cigarette lighter adapter. Your results may be different but it never hurts to use regulated power. I can garuntee the power coming from your computer psu will be cleaner than the power coming from the adapter.
    RevFE
    My Shop
    Feb 2007
    Taylorsville, UT
    Quote Originally Posted by WillyWonka View Post
    TIA
    Because the 12v in the dash isnt regulated. Car 12v generally runs around 14v and jumps all over the place, electronics don't really like that.
    Personally, I run +12v and +5v from my pc's PSU to power the LCD, and USB hub respectively.
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 920@4Ghz, 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
    May 2006
    Calgary, Alberta
    TIA
    "I got a computer. How should I power it?"
    See how vague my question is? That's what you just did, without any reference to your hardware, your car nor anything at all, nobody here can tell you how to power the mystery hardware you're talking about.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Feb 2007
    Taylorsville, UT
    I dont think his question was too abstract...
    -James
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    If it's a lilliput, then you probably should run it on regulated power. most xenarcs have internal voltage regulation I believe. Confirm with the manual to make sure.
    Dec 2008
    the monitor will come with a 12v regulator, but it wont be a good as what your power supply does. in my car, the supplied regulator works fine, but if you find your screen doesnt look as steady as it should then try running it right off your power supply.
    Raw Wave
    Nov 2009
    If it's intended for vehicle use, its raw power should be okay except for voltage dips (that are regulated upwards by separate supplies).
    The raw car supply is quite unfriendly though and devices require better regulation and spike protection than if powered from a domestic rectifier or charger with optional battery etc.
    Hence as above, most will run through their supply.
    And if your battery does get reverse connected or struck by lighting or your system's voltage goes way out, better to lose your DC-DC converter only than the LCD as well.
    Dec 2007
    ohio
    Quote Originally Posted by OldSpark View Post
    electronics downstream of the converter can still be affected; depending on the quality of the components and the magnitude/type of short.
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    I've got a xenarc 702tsv, and I used to power it from my carnetix 2140 psu...now I've switched to the cig adapter....
    I used to get a squiggly kinda sound out of my tweeters when the 2140 was powering it...it would go away when i turned it (xenarc) off..so I decided to try the cig directly into xenarc...no more squiggly sound...oh...and picture is just the same...
    ymmv
  1. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
