Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 54
Thread: Changing cold cathode backlighting to LEDs (+auto brightness control)
  1. #21
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I got the cold white and it was fine. I may have bumped up red just a little but it looks fine to me.
    For PBCs, Sniiki could post the gerber files on BatchPCB and make them public. Then all you would have to do is buy them. Just an option. It would take about 1 month and I'm not sure the fab guys (gold phoenix) will V-score something that thin. Cost would be at least $20.
    Right angle is probably a bad idea.
  2. #22
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    OK, not right angle then.
    I do not mind makeing the board, making gerber public, and assemble for those who want it. Only hatch is that I will make it to fit my 6.5' panel:-) But I want to be sure I get a good diod first. I found a few alternatives. Trubble is how to test them. And how many mcd is required really? (total)
    EL67-21UWC SMD (states full color LCD backlight)
    19-213/W1D 0603
    12-215/W1D-AN (right angle)
    12-215/W1D-P2
    EL17-21/W1D 0805
  3. #23
    Mar 2004
    Florence Yall, BFKY
    Considering the strip I used was 30 LEDs, 1200mcd and look about the size of that EL67-21, and it's double the brightness, I think you could get away with anything even half that, warm/cold/natural. Even mine needs to be dimmed at night. I prefer map lights to light the interior.
    I think the important thing is to measure the space first. My CCF was a 0.100" U-shaped tube and I did like thanh150 and put them around the outside. The tube could probably fit back in, but that's because the flexible curcuit board stuff is so thin but too wide that it had to go on the outside. It also allowed some space between the LEDs and the diffuser to allow the light to spread.
  4. #24
    Sep 2005
    So a total of 36000mcd is more than enough?
    Yes, I need to take my LCD apart and find the mechanical limitations. For now I have just dissassembled a broken LCD with LED backlight at work. With right angle LED's on flexi board.
  5. #25
    Mar 2008
    bes,
    About the LEDs, yeah these are very bright even at half of the nominal current and dimming absolutely mandatory when driving at night. Software dimming won't do as the screen will glow quite bright even when whole screen is full of black.
    Can't say much about how many mcds are needed as don't really know how much these are producing @ 12,5 mA. With nominal current it would be ~150000mcd in total.
    Color tone is a bit greenish on my panel as these leds produce very little of red. I can fix this partly with software color tuning.
    About the PCB: Sorry, but I don't have any layout file of the PCB cause the electroforge guy actually designed it for me while we were discussing and planning the whole thing. And as the electroforge guy told you, this specific board wouldn't fit to your panel anyways so it wouldn't be any good for you.
  6. #26
    Mar 2004
    Florence Yall, BFKY
    It's interesting to see a factory LED backlight. Notice how far apart they are, and are diffused fine, plus they had a reason for doing that. The case left a lot more space for lighting though. The CCF ones have pretty tight space unfortunately so it's a challenge to retrofit.
    Here's another idea. These are the same as the strip LEDs they sell. All hand soldered, and even on the edge which might be an idea but I wouldn't try it. Personally, I'd at least half the LEDs so you have space for traces and a resistor in between every 3rd, plus order a thin PCB if possible.
    sniiki, just adjust the RGB gain on the monitor. It works better than offsetting the video output.
  7. #27
    Jun 2008
    Perth, Western Australia
    What about this stock here? 12V wired, all ready to go, just not sure of the distance between the LED's.
    http://www.besthongkong.com/index.php?cPath=21_76
    Available in white and warm white too, and the price is cheap, 11 bucks for a 50cm strip.
  8. #28
    Oct 2006
    in my research, there is no led strip even near this density. Brightness is difficult to get it too.
  9. #29
    Mar 2004
    Florence Yall, BFKY
    Wow, would like to see 150 Cd. At some point well below that, black is going to be pretty bright even under normal ambient light. The thin LCD panel can only block so much light. That's why sunlight readable is a better (and more expensive) option. Dimming isn't as much a necessity. I'd like to see both in one though someday. LOL
  10. #30
    Dec 2009
  1. Backlight upgrade with 2300mcd SMD LEDs
    By nobb in forum LCD/Display
    Last Post: 12-08-2008, 02:55 PM
  2. Changing LEDs and Updating HDD
    By Deric in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 07-04-2007, 07:14 AM
  3. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 12:20 AM
  4. Changing the color of button leds on lilliput
    By jdbrumsey in forum LCD/Display
    Last Post: 11-02-2005, 09:52 AM
  5. Creating backlight for Projector LCD
    By e_fractal in forum LCD/Display
    Last Post: 08-14-2003, 01:02 PM
