Results 1 to 4 of 4
Thread: Mounting a flip-down
    Sep 2009
    Hey all,
    I have two 15" Lanzar flip-down screens, they're older and pretty hefty... each one weighs about 8 pounds.. they come with metal mounting plates, but I can't help but think I'm going to need something sturdy to screw into like a piece of 1/2" plywood bonded to the roof skin or something otherwise the headliner would hang like sleeve of wizard.
    If it makes a difference, they're going in a '95 Cadillac DeVille - here's a pic of the mounting plate on the monitor:
    Thanks!
    Newbie SCIONology's Avatar
    Dec 2009
    Hickory NC
    i don't know about your car specifically, but most cars have a body support frame going along the roof between the b-pillars; the b-pillars being between your front and rear doors. there should be holes or channels along the body support that you can run the screws through, i believe you'll need to cut an "X" in the headliner where the screen goes to get to the support (make sure the X isn't bigger than the screen, or you'll see cuts after it's installed)
    my advice is to be taken with a grain of salt on this topic, as i've never installed one before, but i do know that the only thing in most cars strong enough to support that would be that support beam.
    Scion xB G2
    Planning: [----------]
    Parts: [----------]
    Install: [----------]
    My Scion PC Project (put on hold until I find a nicer host):
    Worklog
    Sep 2009
    Thanks for the insight SCIONology, I will definitely pull the headliner tomorrow and see exactly what's hanging around up there.
    Dec 2009
    Hickory NC
    this might help:
    if you look at your headliner, you can usually see a bump across the middle, that's where the support is:
    mine is hard to see but if you look right above the pillar you'll see the dip or bump, the cabin light is mounted to it.
    Scion xB G2
    Parts: [----------]
    Worklog
  1. Lilliput 809GL-80NP Flip Features Question
    By kidfob in forum LCD/Display
    Last Post: 01-31-2006, 09:32 PM
  2. Mounting a 700tsv
    By ninjatill in forum LCD/Display
    Last Post: 10-07-2005, 12:47 PM
  3. To gut or not to gut... looking for flip down solution...
    By coachreed in forum General MP3Car Discussion
    Last Post: 05-22-2005, 03:29 PM
  4. Screen Mounting (Flip up or Dual View)
    By lostreception in forum Fabrication
    Last Post: 04-09-2005, 02:26 AM
  5. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
