Problem with TM-701L
I just got my LCD (TM-701L) and I discovered that V1 would diplay both signal from V1 and V2 which cause the picture to distorded. But V2 display ok. Also there is 2 faint line run down the middle of the screen. Does anyone of you experience this problem with your TM-701L.
Unfortunately, I found this forum after I placed an order at MP3Playerstore.com otherwise I would have purchase it at DigitalWW.com. I send them an email for RMA but no response yet.
Re: Problem with TM-701L
It sounds like a bad Controller board. Did the seller reply to your RMA request? When they send you a new screen tell them to double check it before shipping. I try to test every product we sell before shipping to avoid shipping things twice.
Armen
They sent me a new one but has the same problem and I think all of the screen have the two faint lines. This unit actually worse then the first one....there seem to be a ghosting effect when there a high contrast between black and white. I really want to just return the product and get something better.
Armen, when will you have those VGA unit available?
id like to know this as well
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
