Results 1 to 5 of 5
Thread: Help with LCD panel LVDS pinout
    Dec 2009
    So I'm trying to make a custom carputer all-in-one touchscreen. I have a Torisan TFT-LCM MXS121022010 with a 3m overlay touchscreen. I figured out the pinout for the touchscreen and got it working nicely. Now I have a few mini-itx boards with LVDS ports on them, and the connector for this 12.1 inch LCD fits perfectly in the port, but the pins are completely different. I managed to find a datasheet on the pin config, which you can find here: http://www.pdfsea.com/down/down.php?downid=12265&id=0 And I also managed to find the pinout of the itx board, which can be found here: http://www.mp3car.com/vbulletin/atta...ds_mapping.pdf
    I'm hoping someone can make sense of these pinout lists and help me out with getting this screen working with the itx board. once that gets done, I can do the rest. Thanks in advance!
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    The LCD is 6-bit per channel TTL, not LVDS. The two are incompatible without a converter (such as Advantech PCM-3540R).
    Dec 2009
    Quote Originally Posted by Rob Withey View Post
    Thanks for the response. I figured that was the case. I managed to take the screen out of an old CTX EzBook laptop I had in the basement, which is a perfect bolt-up and same plug config as the other screen. It's a Samsung LT121S1-105. I couldnt find the datasheet for the S1, but heres the datasheet for the SS. It shouldnt make a difference. http://beyondinfinite.com/lcd/Librar...T121SS-105.pdf
    Is this LVDS? I'd be very happy if it was
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by CrimsonComputer View Post
    Nope, 18 bit TTL again. The clue is the 6 bits of red, green and blue on page 15 with LSB and MSB marked.
    For LVDS you are looking for 3 or 4 pairs of differential signals (marked as + and -). The LVDS signals are ATX0-3 and BTX0-3 in the ITX pinout link in your first post.
    Dec 2009
    Alright now I see. I also have a ELO 1247L with a missing touch panel, but the screen still works. It's also a TTL, but it's a VGA > TTL connection, so im trying to fit all of the power and converter components into the case along with the ITX board. It seems like I might be able to get this working afterall. If I can, i'll be sure to post pics. Thanks for all the help Rob.
