Results 1 to 9 of 9
Thread: Did I mess up?
    Nov 2008
    Unhappy Did I mess up?
    I just won a 7'' Power Acoustik touch screen Monitor on Ebay. I just found out its resolution is 1440 x 234 I want to use this screen for Mp3s and possibly GPS. What would you suggest now that I have this screen?
    Jan 2008
    being that you have the screen already, you could use a vga-to-composite adapter to use it temporarily(or permenantly) until you have the funds for a vga monitor, or you could re-ebay(rebay?) it, and use the funds towards a purchase of a vga screen.
    Nov 2008
    Quote Originally Posted by soundman98 View Post
    Like these? http://cgi.ebay.com/VGA-to-3-RCA-TV-...item5ad63eb4c7
    http://cgi.ebay.com/PC-VGA-to-TV-RCA...item1c0f507854
    Mar 2006
    Colorado, but Canadian!
    1440x234 is technically accurate but not accurate in the sense that most know about. RGB takes 3 lights per pixel, so really the screen is 480x234 This is not VGA, and you will be very unhappy with the results.
    Just put it back up on ebay, and buy a VGA touchscreen. If the seller hasnt shipped it yet, then contact them and say sorry, offer to pay the $5-$10 listing and closing fees and cut your losses now. You wont recoup all your money re-ebaying (same ? as above )
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2008
    Quote Originally Posted by 2k1Toaster View Post
    Well is it good enough for a temporary start up?
    Mar 2006
    Quote Originally Posted by m35x_touareg View Post
    The one thing you look at every time you use your PC is the screen. It is in essense the portal to the CarPC world.
    I would never tolerate it. Especially since a VGA screens are $160 to $200 on ebay brand new.
    Jan 2008
    i can see both sides here-- if you already have the screen in your hands, then using the second link you posted would work(the first link is for a non-powered cable).
    here is the difference between vga and composite video signals-- try to stay with me
    composite video signals are limited to about 480 lines of resolution, and cannot offer any more resolution.
    vga signals support multiple, higher resolutions, typically starting at 800x600 (though sometimes, with certain hardware, i believe that you can get a lower resolution, like 480x600...). as you should have noticed, there is a huge difference in the minimum resolutions-- meaning that the vga-to-tv converter is removing information to squeeze the 800x600 screen into a 480x*(i can't remember the vertical line rez). so it is removing almost half of the information that makes the vga screen easy to read-- so smaller text, and graphics don't look as amazing as they did on the vga screen...
    like i had said before, it is completly doable if you want it to be, but it will cost you clarity, and a couple extra bucks to make it work..
    Nov 2008
    Soundman will the touch screen still work?
    Jan 2008
    if it connects through usb/rs232(most 7" vga screens use usb these days), then you might be able to install the drivers and get it to work. if it doesn't have either usb or rs232, then i do not think that it will work without some sort modification.
  1. Want new speakers, dont want to mess it up
    By SupaflySoulder in forum Car Audio
    Last Post: 12-07-2009, 07:54 PM
  2. Looking not to mess up my dashboard :)
    By petch41 in forum Newbie - Proposed setup
    Last Post: 09-10-2009, 08:38 PM
  3. Replies: 0
    Last Post: 06-25-2008, 10:31 PM
  4. Please help - 2005 freelander & ipod mess
    By cpearsoneit in forum Car Audio
    Last Post: 01-18-2008, 12:59 AM
  5. can my sub mess with my comp
    By omlax19 in forum Newbie
    Last Post: 06-02-2004, 10:00 PM
