Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Is it possible to modify the VGA and USB plug? They are so big :S
    Jan 2009
    Hi. Is it possible to modify the VGA and USB plug to make them much smaller? The contact points between the vga cable and the screen is kind of tiny (lik 0.5cm long pins), even though the actual plug is gigantic with a really thick cable and even a large lump on the cable about three cm. from the plug. Can't some of this be removed or modified? The screen is mounted fine, but the cable-plugs are streching down in front of the fog-light buttons and stuff, and because the VGA cable is so thick I have to leave one DIN-slot open in order to make room for it.
    May 2006
    Calgary, Alberta
    There are boards inside there that do conversions on the signal. The only thing I can see working is to move that portion farther down the cable line but then you'll have to extend all the individual pins. I'd look online for a custom solution if I were you, try Monoprice.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jan 2008
    Quote Originally Posted by Maheriano View Post
    i think i disagree with you- while there are some connectors with boards inside them, i do not believe that either of those pieces shown should have any...
    the monitor connection 'should' just have a lot of rubber around the wires, and the cylinder on the cord is just a ferrite core to reduce interferance-- which can be removed, but you might get some noise in the picture.
    for the usb, it should not have circutry inside it-- i have taken apart similar ones of those...
    IMO, the primary reasons that they make usb cable connectors so big is so that it is easier to plug in, and also for stress relief of the cable(those wires inside are tiny!)
    though i could be wrong, so dont take my word for it...
    Jan 2009
    So the usb cable shoudnt be any problem? A little chop chop and some playing with the soldering iron shoud be able to remove the plastic "handle"?
    Jan 2008
    nope both connectors can be broken down,
    the two images show you the conector that is inside the vga cable you should be able to remove all of the backing and the ferrite and the cable will work.
    usb's can also be boken down but i am not sure by how much.
    most likley look like the top right of the picture below
    Jan 2009
    So how do I procede? To I have to cut the cable under and above the ferrite and then join them again? The two upper pictures you posted doesnt look very motivating. I though soundman said that there shoudnt be a board inside the VGA cable I posted? If there is no board inside, can I then just remove the backing (this shoud then just be a lump of plastic with two screws going through it, right?)?
    Jan 2008
    the ferrite core can definatly be removed with some 'creative' cutting-- you should not have to cut the actual cable at all.
    the vga connector looks like molded rubber, so you would need to hack it apart without ruining the wires, which would be no easy task...
    Newbie deanb2's Avatar
    Sep 2008
    Calgary, AB
    I use cat5 VGA extenders, something like these. You can find them all over ebay.
    Much easier to run cat5 through the car than a vga cable.
    I suppose that you could remove the shells as well to make them smaller.
    Jan 2009
    Brilliant deanb2 I actually had a problem hiding the thick vga cable, this would be much better. I think I have to remove the shells because that thing looks like it would hide the fog-light button intierly. But what am I looking at if I open that cat5 to VGA plug? Couldnt I just sold the small cat5 wires directly to the vga pins? This would make it as small as it's possible.
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by Plecto View Post
    This is probably what you're after. Should do a similar search here as well, as I think only 5 to 8 of the pins are actually necessary for a VGA connection. I'd give you more specifics, as I've done this myself since I didn't have enough room to house the normal molex VGA connector on the back of my motherboard, but I don't recall exactly everything I did or where I got the info. If no one responds later I'll try to dig up the info when I get home.
    The connector can be bought for like $3 at radio shack to solder the leads onto.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Best way to extend the USB and VGA on Lilliput
    By brianteel in forum LCD/Display
    Last Post: 12-13-2009, 06:48 AM
  3. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 10:50 AM
  4. FS: Liliput 7" TS, Audigy2 NX, USB Cables, VGA
    By joshuaeric in forum Classified Archive
    Last Post: 06-18-2006, 06:24 PM
  5. 8.4" Capacitive USB VGA Touchscreen
    By Euclid in forum Classified Archive
    Last Post: 03-02-2004, 05:04 PM
