Results 1 to 10 of 15
Thread: Speedometer Replacement?
    Jul 2006
    LI, NY
    Lightbulb Speedometer Replacement?
    Has anyone ever tried to do a full speedo replacement? (like an LCD where the guages are currently located)?
    I've been getting this ich to to a full glass cockpit in a car (LCD speedo/LCD center console), and was wondering if anyone has pulled this of yet, or if not, why?
    Jan 2008
    a couple of reasons tyhe biggest 2 being reliablity, and legality...
    from what i have read(which isn't much), most of the systems/software to do it is still windows based-- and windows isn't the most reliable platform to entrust your cars vitals to(i keep spare loaded hdd's for my carputer, and i just play music )...
    then there is the legal issues of having a screen in front of the driver-- in some states, the wording of the law would make a lcd speedo a easy target. the laws are usually worded like "no screens should be visible to the driver of the car"... so it depends on how much you **** the cop off . then there is also the legal issue if something were to happen to the screen--"sorry, officer, my speedo screen went dead, and so i didn't realize i was doing 60 in a 45..."
    Jan 2010
    Indinapolis
    Not ready to start on it yet but an Arduino TouchShield is probably what I'll try out first.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Tiny. Cool, but tiny.
    Want to:
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    I have been pondering this ida myself, and found it to be rubish.
    There's no way to get the gauges via ODB be as good as the originals. From all videos I've seen where there is speedo and RPM, or just one of the two... they are lagish, and you get real high pikes from time to time... Like 25k in RPM on a regular combustion engine and not a Wankel.
    You can still high jack the original signals, and do what ever needed to be done with them.. But still, I would not recomend doing so.
    May 2007
    Another way of doing this is to hack the wires off your guages and relocate them in your boot/trunk, in a box with a camera facing them.
    I've seen this done, and it works real time, and is as accurate as your original guages. Plus you can use the monitor to display other things such as reverse camera, without having to mash up your dash.
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    I have always wanted a combo of the two... I like the look of a LCD gauge cluster but dont trust them like everyone else has said. Even if I ran linux I wouldnt trust it...
    The one thought I keep going make to tint the gauge cluster glass and wire the cluster lights to come on with the key... Thus when key is turned on the blacked out cluster will shine through... Again its just a thought no real world testing to see if that will work. Might have to change the gauges to something brighter and digital. Who knows...
    Edit: Hmm with the space between the gauges and the glass one could pull off some neat lighting tricks...
    NOTE: I know I wrote glass, but what I mean is that clear plastic piece to prevent a dishonest person from rolling back the od..
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Jan 2008
    Quote Originally Posted by SjLucky View Post
    or to keep people like me from playing with the needles on long drives..
    Jul 2003
    Quote Originally Posted by soundman98 View Post
    I thought about that too but I already edited that message like 4 times and said f it... Its a slow day at work with no photoshop or I would be working on skins...
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    It would be sweet to have a setup like the MR2 I've dreamed about a few times
    eg. http://www.autoblog.com/2008/09/11/f...ate-car-puter/
    But yea, stability would be a huge issue
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  1. replacement touchscreen for EBY701
    By FusionFanatic in forum LCD/Display
    Last Post: 12-15-2007, 07:36 PM
  2. Lilliput Touchscreen Replacement: Can't calibrate !!
    By stupidjunior in forum LCD/Display
    Last Post: 10-09-2007, 10:31 AM
  3. Replacement Parts?
    By BLOWNZO6_pc in forum LCD/Display
    Last Post: 09-29-2006, 02:31 PM
  4. Method To Read Speedometer Cable Spin?
    By phoneboi in forum Hardware Development
    Last Post: 08-15-2005, 07:06 PM
  5. Digitalww - replacement TS
    By Paul_ in forum LCD/Display
    Last Post: 01-03-2005, 11:55 AM
