Results 1 to 10 of 10
Thread: Lilliput EBY701-NP vs. Lilliput 629GL-70NP
    Newbie BenKenobi's Avatar
    Jul 2009
    Hi all,
    I'm currently in the process of discerning what 7inch monitor I wanna stick in my scion tc with these handy fitting components for a nice factory look:http://store.mp3car.com/ProductDetai...Code=ENC-033-B http://www.installer-parts.com/by_item.php?it=95-8202
    Regardless, I'm not sure which Lilliput I want. From my research, I do believe that the EBY701 is the newer of the two, coming out in 2009, while the 629GL came out in 2008. However, the EBY701 is cheaper than the 629GL. Why is this? Which is better? According to the mp3car.com store, both of them have the auto-backup switch which is something I am looking for.
    Help a newb out
    Jul 2009
    no one knows?
    Newbie dandydanny's Avatar
    Jul 2009
    Los Angeles, CA
    From what I figured out by reading past posts:
    Both monitors now contains the same LCD panel. The big difference between them is the shape and the arrangement of the internal circuit boards. This may come into play if you're doing custom fabrication, but in your application, EBY-701 should work fine.
    Dec 2006
    India
    I guess the touchscreen is better on 629GL when compared to EBY701. But I'd wait till the experts comment.
    Apr 2007
    Are they really the same? the 629 says its LED where as the 701 does not mention it
    The 701 would suit my use better but if its inferior might have to find another way around...
    Newbie NOVAK's Avatar
    Oct 2009
    Sacramento, California
    I believe the newer models are exactly the same. I believe that the only difference is the case that it comes in from the factory. I actually broke the touch panel on my EBY-701 and replaced it with a 629 touch panel and it works fine.
    Dec 2006
    India
    A note from Mo-Co-So website. This should clear the confusion.
    "There is no longer any difference in hardware between the EBY701 and the 629GL. The internal components are identical. Only the outer plastic housing is different. Unless you like the way the GL629 looks better then the 701 there is no reason the purchase it over the EBY701."
    Apr 2007
    thanks EBY ordered
    Jul 2009
    yeah, save yourself the 50 dollars
    Scion Tc 2005 RS 1.0
    Planning 50%
    Building 0%
    Jul 2009
    60 dollars actually
    Planning 50%
    Building 0%
  1. WTB: lilliput 629gl front bezel
    By itech in forum Classifieds
    Last Post: 05-16-2009, 03:04 AM
  2. Lilliput 629gl
    By snowspeeder in forum Input Devices
    Last Post: 01-19-2009, 10:10 PM
  3. WTB: Lilliput eby701 remote
    By bassboy3313 in forum Classifieds
    Last Post: 12-13-2008, 10:51 PM
  4. Lilliput 629GL Head Rest Shroud?
    By ThunderStick in forum MP3Car Products - store.mp3car.com
    Last Post: 06-29-2008, 08:57 AM
  5. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 06:26 PM
