Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: EBY-701 2009 Model what settings for 800x480?
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    I have a 2009 model Lilliput EBY-701, this one specifically:
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=190336087290
    I have searched and searched but I cannot find out anyone who has gotten 800x480 to work with the Nvidia ION chipset.
    Does anyone have some Powerstrip settings they can post? Thanks.
    Also, please don't just tell me to run in 800x600; I am and I would prefer a proper widescreen resolution.
    Dec 2009
    I haven't gotten it to work on my 629, either.
    Aug 2009
    Virginia
    No one has any clue? Common monitor, fairly common chipset, and no one can help me?
    Mar 2007
    Atlanta, GA
    I don't think it's a matter of wanting to help you, it's just that getting that magical 800x480 resolution to work properly takes some "magic" if you will.
    I have the 2008 Lilliput 629, using an onboard ATI X700 graphics chipset, and I couldn't get 800x480 to work at all, even with powerstrip (powerstrip actually won't even let me adjust timings with that chipset, so I'm pretty much stuck with no options).
    There are a few threads you can search around where people have posted timings to try and get it to work. Most of them are with Intel video drivers though. I think you probably won't get many responses due to most people not using the ION chipset (yet).
    Best recommendation I can give you is to just try and play with the settings in powerstrip if the ION won't do 800x480 natively.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    That gpu can definitely do 800x480 (works fine on other non-ion platforms). It may need the unlocked drivers though.
    Newbie dandydanny's Avatar
    Jul 2009
    Los Angeles, CA
    My 2009 EBY701 (purchased from Mobile Computing Solutions just arrived yesterday) does not display 800x480 correctly when tested on two different graphic cards. There are visible horizontal scaling artifacts.
    You may find that your monitor displays best on (gasp) 800x600.
    EDIT:
    I finally got the darn thing to display 800x480 @ 55Hz (using a modified driver, this is an Intel 945 board by the way). The monitor is capable of displaying native 800x480, but apparently is very picky on timing.
    Sep 2005
    Bay Area
    Not sure if this applies to to the Lilliputs as I have a Xenarc and Zotac MB with 7100 gpu. This gpu is also supposed to be able to set the magical 800x480 res, but I cannot. I've ended up using the 1280x720 res (I know it's small, but it's ok for me), but my skin is 800x480 and after RideRunner starts up then everything is ok (even though the monitor's osd is reporting 640x480.
    Aug 2009
    Virginia
    Quote Originally Posted by black_mamba View Post
    What skin are you using?
    Jan 2010
    I'd also like to know how. I have the same setup.
    Jan 2010
    I'm thinking about a Zotac MB but the native resolution is pretty important to me. So I've been doing research and stumbled on this: http://www.viacarpc.de/community/car...?topic_id=4356
    Maybe that helps you guys.
  1. 2009 Model LILLIPUT 8" 889GL-80NP/C/T
    By SoulR in forum LCD/Display
    Last Post: 01-10-2009, 07:38 AM
  2. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 10:33 AM
  3. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  4. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  5. [Release] SKINbedder BETA 2.99999
    By 0l33l in forum SkinBedder
    Last Post: 09-23-2005, 04:38 AM
