Results 1 to 10 of 16
Thread: Will a relay work for this ????
    Apr 2009
    Newark, New Jersey, United States
    I will like to power my lilliput lcd via the 12v rail on my molex connector.
    I have the dsatx and i have it set to turn off the pc after 12mins from me exiting the car.
    I do not want the monitor to stay on for 12mins after i have exited.
    Is it possible to attach a relay and i have wired to the acc line?
    that way the screen can turn OFF wen i take the key out of the ignition?
    Elsewhere
    The DSATX has an additional 12v output.
    I'm not certain if that is controlled by the shutdown controller timings or not. If not, you can use that 12v output for your Lilliput, and it will do exactly what you need.
    Another way of accomplishing this is to use the egg-shaped regulator to power the screen directly form an ACC-controlled line. That is probably a far simpler means of accomplishing what you want.
    How about the Wiki?
    Apr 2009
    i forgot to mention a few things
    the lcd is currently powered by the acc controlled cigarette lighter.
    but the screen flickers when the bass hits. (i have a sub in the trunk)
    so my intention is to power the lcd with "cleaner, more stable" current; connecting it to the dsatx.
    the only problem with that configuration is when ever the carpc turns on , so will the screen.
    i live in a bad neighborhood , and i use remote start.
    i dont want to have the lcd on, attracting attention wen i am not in the car.
    hence, my quest for a acc controlled line running from the dsatx.
    i still want the pc to turn on with the car, and off after 12mins etc.
    hope u can follow my thought processes...
    Apr 2009
    here is a pic of how i want it to look.
    the dsatx can be started by both the remote start or the acc line.
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    Quote Originally Posted by trinybwoy View Post
    Sure. That'll work fine.
    If it's a standard 4-pin relay, just connect it like normal using the DSATX as source.
    30 - Positive from DSATX
    85 - Ground
    86 - Positive ACC
    87 - Lilliput
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
    Apr 2009
    Quote Originally Posted by Superduck View Post
    85 - Ground
    86 - Positive ACC
    87 - Lilliput
    Cheers,
    Kris
    thank you
    im soo happy lol, u made my day
    i will setup this weekend.
    is there any special relay i need to get, like a 12v 30amp?
    i think that may be an overkill..
    Constant Bitrate popi79's Avatar
    Sep 2006
    Yes.
    Remember to use a relay with a diode...
    because energy can store at relay coil and kill your psu...
    "Most of the users you'll see in this site are still learning specially me"
    Apr 2009
    Quote Originally Posted by popi79 View Post
    can u possibly recommend a diode for such use?
    I've never ventured that far in my electronic endeavors
    Sep 2006
    Relay
    a good quality relay like bosch will have it from factory.... or a 1 amp diode will do...
    like this...
    http://www.ripper1.com/tech/wiring/bosch_relay.gif
    Apr 2009
    thank you sir.
  1. Replies: 0
    Last Post: 04-03-2008, 08:30 PM
  2. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  3. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 08:55 PM
  4. Replies: 52
    Last Post: 09-28-2004, 06:38 PM
  5. Remote Shutdown Circuit - Would This Work?
    By owenjh in forum Power Supplies
    Last Post: 09-01-2004, 11:43 PM
