Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Retrofit new LCD into aftermarket screen-based head unit
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    I did a bit of searching and didn't really find anything, but I also wasn't sure what exactly to put in for search terms so I may have looked right past something.
    That being said, I may be totally off my rocker with this, but I've been looking at a couple of new cars and trying to figure ways to install a carputer in each. In my current setup I have a screen and a head-unit installed in my Forester and really like the setup. Unfortunately the new Foresters don't offer a gauge pod in addition to the double din stereo opening.
    From what I've been able to gather, the biggest problem with the flip-out LCD's lies in the mechanisms. They break, don't hold the screen well, etc... The aftermarket flip-out head units I've seen seem to have pretty solid mechanics and the screen's feel rock solid when they're extended. This got me thinking, why not take a used or broken (broken radio portion/display, etc...) and retrofit one of our LCD's into it. Has this been attempted before, or completed?
    This is the style head unit I'm talking about:
    The second thought is even more out there, and probably way way too much work, if it's even possible, but I wanted to through it out there. The thought is similar to the previous idea, but instead using a double-din screen-based head unit. The LCD that came in the unit would be removed and replaced with a Lilliput or Xenarc panel. This would be much more complex because I'd need to maintain all of the factory functionality. I suppose to make it work the factory display feed would need to be converted and fed back into the new panel. I'm guessing there's not a lot of free space inside the unit, so that'd make this idea even harder.
    This is the style head unit for the second idea:
    So, does anyone think it's even possible, or have I officially lost my mind?
    Mar 2006
    Colorado, but Canadian!
    Everything is possible with the right amount of work and know-how.
    Idea #1 I have not seen anybody try but it seems possible. The hardest part will be creating a flexible ribbon from the LCD to the controller board that will work with the swivelly thing.
    Idea #2, seems the same as #1 to me. For both of them you would need to overlay the OEM stuff onto the new screen.
    To me it seems like the easiest would be to find a unit that uses standard rgb/composite feed to the stock lcd controller. Then splice those signal lines into an overlay module into the VGA signal, then run that VGA signal into the retrofitted lcd controller to be displayed on the retrofitted screen.
    1.9in x 2.9in -- 47mm x 73mm
    Minneapolis, MN
    In the case of #1, I would run another dedicated head unit to avoid any problems needing to keep the original video feed. Basically just cannibalizing the case and mechanism.
    Mar 2006
    If you are going to go through the trouble of retrofitting, go all the way! Down with #1, go #2!
    Minneapolis, MN
    I'm thinking about trying to find the cheapest unit I can at a pawn shop and a broken lilliput/xenarc simply to perform a test/proof of concept to make sure I can even make things fit before spending real $$$ on the good parts. Especially since I'm hoping to use a transflective panel.
    Mar 2006
    Quote Originally Posted by techy101 View Post
    Keep in mind, these units generally use 6.5" screens, our screens are generally 7.0". You will need to modify the casing, to what extent and if possible, who knows.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Your not gonna have the space for a lilliput or a xenarc...they have ribbon cables which you can't really hack up to extend. Also, like 2k1toaster said, most of those are 6.5" not 7" screens.
    You're better off with an aftermarket lvds unit.
    Mar 2006
    Quote Originally Posted by justchat_1 View Post
    it is possible to extend the ribbon. On the ZIF connection end, the pins are exposed. With some solder skill you can do it. Or another alternative is to buy 2 ZIF sockets, connect them together. Then you can do:
    LCD --> Stock Ribbon Cable --> ZIF Socket --> Direct Solder/Small wires --> ZIF Socket --> New Ribbon Cable --> Stock LCD ZIF Socket
    Minneapolis, MN
    I've been working on surface mount soldering recently. More practice is needed, but this was where I was at a couple of weeks ago:
    Here's a pic of three resistors for size comparison:
    And here's those installed on the practice board. They're sloppy, I've gotten a bit better, but I really need to buy myself a loupe to make these things easier. (again, the pen is for size comparison)
    Mar 2006
    0603, 0805, and 1210 sizes are small, but they come much smaller. 0402, 0201, and then the devil that is 01005!
    A ZIF socket's pitch is nowhere near as fine, and I'm sure with a steady hand you can do it.
  1. Head unit with video out and no screen
    By dodguy in forum Input Devices
    Last Post: 07-02-2006, 06:06 PM
