Results 1 to 10 of 11
Thread: Composite (RCA) to Vga Need Help
    Apr 2003
    pls Help me out, plan to use a samsung 15" LCD monitor on my car, anyone know how to make a composite (rca) to Vga adapter/inverter, or where can a buy one of those need links, pls help me out thanks a lot
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    I'm not getting the full picture here. Can you give us a little more detail on what your project is going to be?
    1) What's the source, and what kind of signal does it output? Is it a VGA computer with both VGA out and TV out? Is it a DVD player or Playstation?
    2) What's the skinny on that screen you're trying to use? Is it an off-the-shelf LCD monitor for computers? Is it a LCD TV? Does it accept DVI and/or VGA and/or RCA or composite video?
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    i take it thats an off the self screen.. so why use composite.. just use vga..
    '98 Explorer Sport
    80% done
    Jan 2002
    Oakland, CA
    degredation of the signal perhaps. Running VGA from the trunk of a car tends to really mess it up
    Aug 2002
    longview washington
    buy some nice shielded bulk high quality wire and make your own extension or get a vga signal amp meant for use on remote setups where you have like 4 or 5 puters a switch box and one k mouse and monitor
    WINNER!!!!
    run-on sentance comp 2002!!
    Apr 2003
    which would be better? a 15-pin VGA cable or the RCA video out cable?
    Jan 2002
    Oakland, CA
    VGA is better for clarity, hands down. RCA is more easily split and will travel over longer distances.
    Apr 2003
    i have a pioneer dvd player avh-p7300 dvd and it has a rca output to connect to other monitor and im planning to use a out-off the shelf computer monitor and its input to it is a vga input, i want to connect it with out the use of a cpu, just plain rca to vga connection, is there a diagram on how to make that connector? thanks
    Mar 2003
    I don't know of any way to simply wire it together. But I would use a Viewsonic TV Tuner. It accepts composite RCA in, svideo, and coax for TV. The VGA from computer also passes through it. I have one and love it. Switch between Computer>XBOX>CCTV night-vision camera in the hall>~70 TV channels>back to Computer all with a nice remote. It also handles channeling all the audio correctly. I am especially impressed with the remote, as it is super strong sending and recieving the signal, I can bounce the signal off the ceiling and walls from across the room.
    I got it for about $65 and it was well worth it as I can watch TV without the hum of the PC and can check the hallway in the middle of the night for intruding infidels
    I was going to run this in my car but decided to just put a decent PCI TV Tuner in there and wait the 40 seconds boot time for RCA input.
    http://www.viewsonic.com/products/video_box_vb50hrtv.htm
    Apr 2003
    thanks
