Results 1 to 6 of 6
Thread: Monitor+relay+Acc
    Dec 2006
    Monitor+relay+Acc
    How can I wire a 12v relay to the ACC to turn off the monitor? I have the monitor hookup to the M4 yellow and black.
    Because when I go in a store and I hit the override switch the monitor stays on…and sometimes I for get to turn it off when I get out of the car.
    Raw Wave
    Nov 2009
    A plain SPST (on-off) relay.
    The input +12V power for the monitor to relay #30.
    +12V power to the monitor from #87.
    +12V from ACC to #86.
    Ground to #85.
    Dec 2006
    So like this
    Raw Wave
    Nov 2009
    Assuming "PC" is the power source (+12V or whatever) for the monitor, then yes.
    Dec 2006
    Thanks OldSpark...
    I will give it a try this weekend.
    Dec 2006
    It works...
    What I did was...run both ground the monitor and pin 85 to the M4 ground and pin 30 to the M4 yellow 12v. That way the pc still give clean power to the monitor and not the car power.
    Thanks OldSpark for helping me out on that.....
  1. Turning key from ACC to Crank = Laptop will standby
    By l00kster in forum Power Supplies
    Last Post: 11-15-2007, 02:27 PM
  2. M2-ATX feedback - ACC line
    By piabu in forum Power Supplies
    Last Post: 02-18-2006, 01:32 AM
  3. Difference between ACC and Ignition wire?
    By bluehcc in forum Power Supplies
    Last Post: 05-12-2005, 05:30 PM
  4. Acc Line from Steering Column?
    By Coeus in forum Power Supplies
    Last Post: 01-20-2005, 10:11 PM
  5. ACC Wire Dead!
    By bambooracer in forum General Hardware Discussion
    Last Post: 03-29-2004, 05:25 PM
