Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: EBY-701 Native Auto-Switch Modification/Enable
  1. #31
    Newbie jakal's Avatar
    Sep 2009
    Southern California
    Quote Originally Posted by maxthebuilder View Post
    Mine looks like this too. Transistor/resistors are already there but there's no wire. So the only mod needed is to solder a wire to the right place. You need to trace that Cu line - it goes right then turns right/down to a bunch of empty connector holes - the one you need is the 4th from top on the right row.
    I too have this same board from and EBY-701 and this is where he is talking about soldering the wire for reverse input. Um not sure if i inserted photo correctly
    Name:  EBY-701 reverse.JPG
  2. #32
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by chrislamb View Post
    utd09bry,
    just did this mod to my lilly and bingo, auto reverse cam input, many thanks for an excellent write up.
    I silly question, what colour phone is VIDEO2 input, red or yellow?
    Cheers
    Chris
    Warwick, UK
    Can't remember, and I'd have to rip things apart to check. Maybe someone else can help?
    I'd say trial and error, though
  3. #33
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    OK found it in this.
    http://www.carcomputer.co.uk/shop/mo...l-70np-c-t-pdf
    1. SKS input end connect the SKS input jack of the unit
    2. Black 9-pin plug for VGA signal input
    3. Black jack DC12v power input
    4. Yellow RCA jack for video 1 input
    5. White RCA jack for audio input
    6. Red RCA jack for video 2 input
    Thanks again for the write up, I could not have done this without it.
    Cheers
    Chris
    MINI COOPER S PRO
  4. #34
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I need to get my monitor open so i can see. I remember last time i looked I wasn't able to find the componants. Maybe i have a 619. Anyways i need to do the fix for the touchscreen anyways so i am cracking it open soon. Any others with different models of lilliputs (sunlight readable) have any luck with this
    Edit: I believe this is the board i have. Any chance we could identify the part area of interest?
    Secure LCD to Bezel
  5. #35
    Nov 2009
    corona ca
    I am an archeologist, digging up this old thread!!! I had to say thanks to the OP because I just followed his instructions with success! I will add that i am glad I ordered extra parts because one of those 10Kohm disappeared (flew into the air) when I opened the package. All I could do was laugh because there was no way I would ever find that part again.
  6. #36
    Dec 2012
    Hi,
    Im having the same problem...anyone can help me?My problem is...for this board...i need the npn transistor or just connect the 12v cable? This is the my lilliput:
Size:  106.3 KBName:  a20121220_134746.jpg
  7. #37
    Newbie ProGEEK's Avatar
    Aug 2013
    Karori, New Zealand, New Zealand
    Quote Originally Posted by nitrousnx View Post
    Hi,
    Reviving a potentially very dead thread, but my Lilliput looks exactly the same as this one.
    nitrousnx, Did you find a solution to this question? Or can anyone else shed any light on this?
    I know this board supports the auto-switch backup camera as there are numerous pictures online of the same board with the wire
    This board is an EBY701-NP/C/T
    The barcode reads: EBYB720150043 (As shown in this mp3car picture)
  8. #38
    Dec 2012
    [QUOTE=ProGEEK;1496891]Reviving a potentially very dead thread, but my Lilliput looks exactly the same as this one.
    Hi ProGEEK,
    If your board is the same as my pictures, you need to solder de cable and one npn transistor(don't remeber exactly witch one...guess BC847) to get the switch working.
    Solder in positions as show in this picture and switch will work on AV1, in the other spaces is AV2.
    http://www.mp3car.com/vbulletin/atta...220_134706.jpg
    Be careful soldering, only do this if you know what are you doing =)
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  2. lilliput auto switch video
    By p4intel in forum General Hardware Discussion
    Last Post: 04-08-2005, 11:34 AM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. Auto video switch on lilliput
    By NEO in forum LCD/Display
    Last Post: 09-16-2004, 12:14 PM
