Results 1 to 2 of 2
Thread: Xenarc 1020TSV question
    Constant Bitrate shiltz's Avatar
    Dec 2004
    I think my old 700TSV is on it's way out I think so i've been looking at new monitors for a while and wanted to go larger, 10.2" seems to be about the largest I can fit so I wanted to go with the 1020TSV which I had looked at a while back, however I noticed it's been upgraded for 2010 with a 5-wire touchscreen which is a plus, however there's one thing that worries me but i'm wondering if it's a typo, on the spec it says "Upgraded High-Brightness LED Backlight *New*", but then in the technical spec it says "LCD Brightness: 300 cd/mē" which is quite a downgrade from last years model which was 400cd/mē but since it says the backlight was upgraded I would thing it should actually be better then not worse, so does anyone know if the 300cd/mē is actually a typo and it's really in fact upgraded from the old 400cd/mē, or is it really downgraded in brightness from the old model?
    I know 400cd/mē I can live with because that's what my 700TSV is (it's a much older model), but anything lower I can see as acceptable seeing as I do have some issues seeing the display during the day with my current monitor.
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Not sure how useful is all this info. Xenarc reports the same brightness and contrast ratio for Touch and non-Touch monitors, so how can we trust these numbers are consistent?
    I know that when Dell first released the Convertible Tablet PC XT/XT2 with LEDs, it kept the outdoor screen version with CCFL lamps. Only later it also offered LEDs for the Outdoor screen version, so I think it's costly to achieve the same brightness with LEDs...
  1. Building a custom cable for a Xenarc 706TSV... impendance question
    By Pseudo Nim in forum Hardware Development
    Last Post: 10-24-2009, 09:24 AM
  2. Touch screen question :Xenarc screen
    By Outsider787 in forum Software & Software Development
    Last Post: 08-21-2009, 08:17 PM
  3. Replies: 0
    Last Post: 01-25-2009, 08:26 PM
  4. Xenarc 7inch power question (I did my research)
    By potpeye in forum LCD/Display
    Last Post: 06-05-2008, 04:53 PM
  5. xenarc brightness question
    By tymans in forum LCD/Display
    Last Post: 05-15-2006, 12:54 PM
