Results 1 to 10 of 13
Thread: lilliput eby701 flashing off then on
    Nov 2009
    Thunder Bay, Ontario, Canada
    I recently added a backup camera to my setup, and my lilliput from mo-co-so with the auto switch feature switches perfectly. I wired the trailer hitch wiring's reverse light wire directly to my camera's positive and the green wire on the back of the monitor, in parallel with this wire. My problem now is, that I noticed occassionally when i press my brakes that the monitor will flash black and "PC" will show in the corner, as if it momentarily wants to switch off or switch inputs. It's not the same as if i pull the power to the monitor which produces a much longer delay, I thought it might be a power issue so i gave this a try to rule it out. it seems more like the switching of inputs. The monitor is currently being powered by the 12v lighter socket.
    The other thing that is throwing me off is that it usually seems to happen when i press the brakes. could it be a ground issue? it's grounded only at the camera end, to the frame.
    Dec 2009
    hi
    iam about to wire mine too and talked to chis from the mo-co-so and he gave me some tips to do it but really did not try it yet because i did not really understand what was he saying . that is what he tald me if that helps.
    power your camera, plug it in to one of the yellow RCA jacks, put 12v to the green wire of the monitor, if you get the camera image you know you have RCA #2, if not you just need to switch. Run a wire between the reverse brake light bulb + and the green line on the monitor.
    Nov 2009
    Quote Originally Posted by enbeya View Post
    hi
    on mine the red rca is video 2. And my setup switches and works fine, aside from the fact the when i'm not in reverse and i press the brake, it want's to switch but it's not recieving 12v on the wire or any video input so it automatically switches back to pc.
    Vendor - Mo-Co-So
    Nov 2005
    It has something to do with the way you have the reverse wire connected. Did you try connecting it to your reverse brake light bulb not the trailer wiring?
    Dec 2009
    hi Thunderbay
    I tried mine today but did not even switch this is how I connected it :
    powered the screen from my M4 ATX , connected a wire comming straight from my reverse light bulb to the green wire on the back of the screen . and powered my back up camera from a reverse buld + 12 .and ground.
    if u got urs working plz tell me how is ur wiring . I spent hours searching but no luck .
    thanx
    Vendor - Mo-Co-So
    Nov 2005
    work on 1 thing at a time. The monitor will auto switch with or w/o a camera connected. Just make sure you have the + side of the reverse bulb. Dont worry about the camera until you get it sorted out.
    Dec 2009
    hi theonlykid
    hopfully you have any idea about powering mine cos chris " thankfull to him was very helfull but just i didnt understand ".
    Dec 2009
    thanx theonlykid
    but is it still possible even if my screen powered from my PSU M4. not from the cigarate lighter
    Vendor - Mo-Co-So
    Nov 2005
    LOL!!!!!!! I am Chris. Yes you can power the monitor from the PSU.
    Dec 2009
    lol at least I did not say some thing bad I said thank you ,just cos english is not my first language lol
  1. Fixed: Lilliput EBY701 - vertical line across LCD
    By geirab in forum LCD/Display
    Last Post: 10-30-2009, 06:13 AM
  2. Replies: 0
    Last Post: 10-01-2009, 04:20 PM
  3. Lilliput EBY701 Housing Question
    By TTeuer in forum LCD/Display
    Last Post: 02-02-2008, 01:16 AM
  4. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  5. Lilliput composite input flashing?
    By Misanthro in forum LCD/Display
    Last Post: 12-09-2003, 04:58 PM
