Results 1 to 5 of 5
Thread: Xenarc 702 TSV Ribbon Cable
    Nov 2008
    Hey guys, so once I got everything working with my Car PC (well, at least to the point it can replace my headunit it my car), I wanted to start working on a case for the system.
    My plan, as I will have two DIN slots available, is to mount the LCD and all the components into a single case, and mount it directly in the double din area.
    So I've opened up my Xenarc 702 TSV a few times now. The first time to see how everything was hooked up to get a rough idea, and then the second time was to measure everything.
    And finally, this time my plan was to do a mock up of all the components in a cardboard case.
    Unfortunately, I have no idea how to remove the ribbon cable, so I can pull everything apart. Any advice would be great! I've gotten the five-wire touchscreen removed, and the power connectors for the backlight. All that's left to separate everything is the ribbon cable
    Attached is a picture of the ribbon cable, you can see how it actually runs through a hole in the PCB to get to the LCD.
    I've tried lifting the white plastic piece (if it's a push down type)...nope.
    I've tried pushing it away from the black mounting point (clip in type)....nope.
    Someone on the forums had this image, showing how to mount a cable, but I don't think it applies to this adapter:
    http://i110.photobucket.com/albums/n..._insertion.gif
    I'm gonna keep doing more research, but if anyone has any advice, that would be great, thanks!
    Nov 2008
    Hmmm, I played around with a it a little more, and it seemed the the black part was actually the piece that locks the FFC in place. Maybe it's a Zero-Insertion-Force type cable, but the locking/clamp mechanism snaps in the back. I'll try messing around with it a bit more when I get home tonight.
    Nov 2008
    I have had no luck with this....but I'm trying to be careful as I don't want to snap the mount off the board.....does anyone have any suggestions?
    I was hoping to setup my system with a nice OEM look, and I won't be able to do that if I can't undo the FCC
    Newbie xenarctech's Avatar
    Aug 2009
    You just lift the black plastic piece up carefully to unlock. Please feel free to contact us directly if you have any question.
    Nov 2008
    Quote Originally Posted by xenarctech View Post
    Thank you so much! Worked perfectly!
  1. xenarc ribbon cable
    By villybhakta in forum LCD/Display
    Last Post: 06-18-2007, 02:24 PM
  2. Where to buy Xenarc ribbon cable
    By dmurray14 in forum General Hardware Discussion
    Last Post: 05-04-2006, 09:06 PM
  3. need replacement ribbon cable + connector
    By keyvan in forum LCD/Display
    Last Post: 04-05-2006, 01:22 AM
  4. FS: Xenarc 700-IDT & 16-ft Cable - BRAND NEW!
    By hd54321 in forum Classified Archive
    Last Post: 09-27-2005, 04:02 PM
  5. Lilly Ribbon Cable Extension
    By Willow in forum LCD/Display
    Last Post: 07-07-2005, 03:51 PM
