Results 1 to 6 of 6
Thread: Lilliput touch screen won't "touch"! Please help!!
    Apr 2005
    Black River Falls, WI
    Hi guys, long time reader, haven't posted much. After a few years, I've finally got my car pc ready. I'll be finishing up a few final touches on the install tomorrow in the car, so I decided to bring the pc in and load up the OS and everything in house tonight.
    I have a Lilliput EBY701 touch screen hooked up via USB on a Windows 7 64 bit OS. The video is GeForce 7100 (from my motherboard's onboard nForce 630i). All the latest drivers/updates have been installed. The display is fine, everything's working great, except the screen doesn't recognize when I touch it.
    After struggling with "no more controller" error for awhile, I finally got the latest Win 7 drivers from www.touchkit.com/drivers.htm
    Now, the Touchkit software recognizes a USB touchscreen controller is installed, and everything seems to be good software/driver wise, but I can't for the life of me figure out why this thing won't respond.
    I'm really excited to get this install finished, its been 4 years, and this last stupid problem is holding me back!!
    All help is appreciated, please help!! Thanks!
    Oct 2009
    I'm in a similar situation. I am about to try these:
    http://210.64.17.162/web20/eg/drivers.htm
    the one you link to seems to be old.
    Newbie NOVAK's Avatar
    Oct 2009
    Sacramento, California
    Quote Originally Posted by zoned019 View Post
    If your screen is mounted in a bybyte double din frame or something similar, or if you took the screen apart from the stock casing and installed it into a LCD frame yourself, the ribbon coming from the touch panel might be inserted backwards into the controller board. Try reversing the ribbon. I had the same problem that you did when I first tried to set my screen up.
    Oct 2009
    the egalax drivers that i linked to above work like a charm, I was getting an uncalibratable touch screen until i used those drivers. Hope you are able to fix your screen!
    Apr 2005
    Even the eGalax drivers aren't working. It must be a hardware issue.. I did install it in a Bybyte frame. I will check the direction of the ribbon cable when I get home tonight and post back. Thanks!
    Oct 2009
    Don't use the egalax drivers, I prefer the Touch Kit drivers. Just my 2 cents.
  1. Lilliput UM-80/C/T USB powered touch screen
    By optikalefx in forum Mp3Car Blog Talk
    Last Post: 07-15-2010, 02:47 PM
  2. Lilliput 629 touch screen hibernation issue
    By jeremy480 in forum LCD/Display
    Last Post: 09-30-2008, 12:02 PM
  3. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 10:10 AM
  4. Lilliput TOUCH SCREEN StOpS !!!!!!!!
    By vicky_obee in forum LCD/Display
    Last Post: 01-07-2007, 06:37 PM
  5. FS: Lilliput 619gl-70np/c/t 7" touch screen
    By kingeorge36 in forum Classified Archive
    Last Post: 05-06-2006, 03:52 PM
