Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 131
Thread: Playstation LCD Hack - Works!!
  1. #21
    Apr 2003
    just a thought - could this have anything to do with the DVI->VGA convertor???
  2. #22
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Shouldn't have to do with the DVI connector, as i used that on mine.
    Try grounding VGA Pin 11. If it still doesn't work after that, ground VGA pin 4 as well.
  3. #23
    Apr 2003
    arrrggghhhhhhhh!!!! :-(
    Tried grounding pins 11 and 4.......
    extending desktop to the display still wont take. Just greys back out after trying to apply. Screen is powered on too when I try.
    I've checked my soldering with a curcuit tester and this is how it currently stands.
    vga1(red)-psx11
    vga2(grn)-psx12
    vga3(blu)-psx9
    vga9-(+5v)-psx10
    vga13-(sync)-psx5
    vga4-(gnd)-psx8
    vga5-(gnd)-psx8
    vga6-(gnd)-psx8
    vga7-(gnd)-psx8
    vga8-(gnd)-psx8
    vga10-(gnd)-psx8
    vga11-(gnd)-psx8
    vga12- not connected
    vga14- not connected
    vga15- not connected
    Its gonna be hard soldering anymore cables in there with the shovel of a soldering iron Ive got!
    Pins12(id1 or sda) and pin15(id3 or scl) - whats sda and csl stand for? do I need them connected up too!?
    any more ideas.........before I sell the damn thing!
    Ian
  4. #24
    Mar 2002
    Isn't there a 'force detection of secondary display' setting in the Radeon control panel?
  5. #25
    May 2002
    Australia
    Can you try plug in a second monitor to the secondary just to get the Radeon to detect a monitor, then unplug the second monitor and plug the LCD in. See if that displays anything?
  6. #26
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    The PS1 LCds... are they 5.6" screens?
    If so this hack + a pair of $8 shroud / mounting kits from Parts Express. And I'll have VGA headrest monitors!
    So... are they 5.6"? I'm going to be REALLY HAPPY if they are!
    Also.. are the PS1 / PS2 screens the same, or does anyone know?
  7. #27
    May 2002
    See if someone can get this working on a gamevue!
  8. #28
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    gamevue
    I ordered parts for the sync on green and h+v->c sync scematics, we'll see later this week
  9. #29
    May 2002
    Australia
    Mine's 13cm diagonal, so that's about 5.1".
    The PCB on the back though is a little larger than the actual LCD, dont' forget to take that into account..
    Just remember that this isn't a standard VGA, so you won't see anything until Powerstrip / X initialises.
  10. #30
    May 2003
    Hi everyone,
    I have one of these PSOne LCD screens as well and I plan to install it into my dash. I've had a skim through this thread and notice everyone talking of wiring layouts and such. I was wondering what you were wiring up exactly ?
    I have this screen working on my laptop at the moment using just the normal power convertor (which I will replace with a cigarette lighter Dc-DC adapter in the car) and a headphone->composite adapter where the headphone jack has 4 segments instead of the normal three (this cable is available from Harvey Norman in Australia). Composite plugs into a VGA->Composite converter.
    This setup works fine driven by X-Windows on my soon-to-be-incar-laptop.
    Hope you can clear up what im missing here !
    S.
