aaaahhh,i see.thank u.im wondering if maybe im grounding out the signal(i have vga pins 4-6-7-8-10-11 grounded.all to psone pin 8.i think ill play around with less grounds and see what i get.thanks again =).
by the way man,did u use an existing vga cable or did u solder up a new one?
i soldered to a VGA header, and used a VGA extension cable from the PC to the header.
Problem with that is that VGA extension cables are really horrible and signal quality goes to crap. I'll probably solder some BNCs on later.
Anyhow, if anyone's in Australia, DSE has PSOne LCDs backorder via their website for less than A$100.. really good.
right on,i was going to try that,but i cant find a vga cable with pin 9.i guess im looking 4 a vesa vga cable.is that what u have?
Mine just has 15 pins straight through. might have to look a little harder!
im really sorry to keep this up,but could u clarify something 4 me?is your vga header plug(the one u have going into the extension)grounded to psone pin 8 via vga pins 6,11,4 or did i misunderstand?i know i must seem really dense at this point but im getting desperate.thank u in advance...
anyone whos interested,i also hacked the car adapter 4 the psone to connect it to my power supply.any one tried this?it was my first thought when i saw that it converts 12v to 7.5.hacking the plastic apart is a bear but i finally got it on a molex.now,lol,im afraid to try it cause someone told me that it would be too much drain on my power supply.if anyone has tried this please let me know.
im sorry,my camera is a creative pc cam 350 ,and i cant get it to work with xp(driver support is very bad at creative)but i will look around inside the box today and post a description tonight.also thank u.quick clarification,u said connect vga ground to ground on psone.do u mean vga pin 5 to psone pin 8 as well,or do i just connect all vga grounds to pin 8?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
