Page 7 of 14 FirstFirst 1234567891011121314 LastLast
Results 61 to 70 of 131
Thread: Playstation LCD Hack - Works!!
  1. #61
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    shouldn't matter, a radeon's a radeon.. and if you're getting horizontal lines then something's getting to the LCD...
    sorry that i haven't posted anything more detailed, have exams coming up and been studying for them..
  2. #62
    Jul 2000
    Ottawa, Canada
    fujikawa23 - on the topic of third party products, this pelican screen isn't so great, the first one didn't work, so i got a second sent. the composite is funny, it looks like the red is shifted to the right by 5mm. but i kept the crapped sceen and now have a 'parts' screen which will useful for taking the dremel to...... the screen is for the DIY projector
    anyways, got home from work and tested my GeForce4; doesn't have CSync but my Rage card does.
    after figuring out the pinouts on the pelican input board i've gotten somewherere
    (get this the pins are arranged 1 3 5 7 9 11 12 10 8 6 4 2 )
    i'm using H and Y sync tired together and connected to Green with a resistor. As per Mpro's site.
    here is the image i get
    http://members.rogers.com/machs_fuel/pelican%20RGB1.jpg
    what can i do to stablize things? it looks B/W........
    i might try using the Csync on the rage tommorow since i'll be using the vid card ideally... it should offer better picture right?
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
  3. #63
    May 2003
    yep,that looks like the signal i got from my geforce.use the rage,if it has comp sync it will definitely look better.btw does the pelican screen have rgb input or did u find the spots on the pcb to send them?let me know if the rage works 4 u
  4. #64
    Jul 2000
    Ottawa, Canada
    oh there was lots of sodering involved with the pelican.
    I'm gonna pick up a VGA extension cord so i can try the Rage card tonight, will inform.
    how well do VGA signals travel? I'm looking at about 20' of cable between the comp and LCD and that would certainly cost mucho $$ and signal quality would probably be crap.
    Is there such thing as USB - VGA card or USB - RGB? that would be pretty useful in this situation....
    EDIT -
    this sounds promising
    http://home.iprimus.com.au/dougburbi...aovercat5.html
  5. #65
    Jul 2000
    Ottawa, Canada
    well no luck over here.... forgot to mention that i'm using a 333 ohm resistor..
    anyways with compsync, on the rage chip i couldn't get much... just flying lines.
    i've played with all the settings with no luck.. i can't get the powerstrip settings to bring the pixel clock down low enough...
    so far the best result has been on the GeForce4...
    Composite is looking might good right about now
  6. #66
    May 2003
    WOOHOO!FINALLY GOT IT!all i had to do was set sync signals to positive.
  7. #67
    May 2003
    sorry,screwed up the upload heres a pic...
  8. #68
    May 2003
    btw could someone please tell me how to run games in a window?i figured id post this here since it seems most relevant...
  9. #69
    Newbie Mikey's Avatar
    May 2003
    Canada
    ya hoo, i found a brand new PS one screen today in a box. one of the bigger comp stores had a tent sale. so i went to take a look, and how lucky can i get... so now i have two, hack one to see if it works and then the other for dual screens. i might even try to put them in the sun visor now too. i hope to have sum crappy pictures soon, since i got motivation to do sum thing now
  10. #70
    May 2003
    starfox,hate to bug ya yet again,but are u running the screen in 8 bit color?it seems to be the only way i can get it to work
