Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 81 to 90 of 131
Thread: Playstation LCD Hack - Works!!
  1. #81
    Nov 2003
    thanks for the help i'm picking up my LCD from EB today :-D mua ha ha!!!!
  2. #82
    Nov 2003
    Apeldoorn, Netherlands
    Quote Originally Posted by WILD9
    http://lagnarok.no-ip.com/index.html thats Mpro's site with the ntsc settings, tbh i dont think theres much difference in the quality, the pal settings give a slightly higher resolution but the screens small so im not convinced the lower resolution for the ntsc settings arn't more readable.
    yup, and the fonts are good to read on tje Mpro's site, with a lower resolution. You dont have to expect great quality like the lilliputs or the xenarc screens.
    Newbee, sorry for my bad english. lol
    Trying to built a carmp3 systeem
    own psu: max788, pt5071, pt5024
  3. #83
    ODC
    ODC is offline
    Nov 2003
    Gday everyone
    ive also got a 5" psone lcd screen
    now ive got an epia mini itx board that has onboard s video which i use to connect to the ps one screen
    i see the windows startup screen fine but when it gets into windows all i see is lines flickering - meaning the resolution is up to high
    is there a program i need to lower the resolution or how can i fix this problem
    cheers
    ODC
  4. #84
    Nov 2003
    Quote Originally Posted by ODC
    Gday everyone
    cheers
    ODC
    Hi, i've an epia motherboard too, and i want to fit the PS ONE LCD with it in my carputer project.
    I've 2 question to tell you:
    1) Where i can find a PSONE LCD as a spare part ??
    2) what kind of model is your Epia ??
    Thank's a lot
    Max
  5. #85
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    If you're using a Composite signal, you shouldn't have to worry about the resolution as composite and svideo signals don't really have a fixed resolution... They should already output video in line with the display's scan rate.
    Maybe you need to muck with your NTSC / PAL settings?
  6. #86
    ODC
    ODC is offline
    Nov 2003
    hi bambuzao,
    i got the 5" psone lcd screen from Myer - i live in Australia - and it was $99
    abd my Epia model is a Via - the same one in the link : http://www.computerhq.com/hardware/p...o-id-3178.html
    hope that helps - if you have any more questions just ask!
    ODC
  7. #87
    Nov 2003
    hi bambuzao,
    ODC
    Thank's a lot man!!!
    Could you pass me the exact setting for Poerstrip ????
    I don't have the monitor yet, but it'll be there in a few days..
    Did you use a specific cicuit to separarte the signals ????
    Tell me more please.....
    Thank you so much !!!
  8. #88
    Newbie WILD9's Avatar
    Nov 2003
    UK Cheltenham
    Quote Originally Posted by bambuzao
    if hes using svideo there are no powerstrip settings as its just the tvout going into the av in on the psone screen, this isnt the same as the rgb vga mod, ive got mine running as a second monitor on the svideo out from my graphics card untill i can figure out how to get windows to recognise it as a second monitor using the vga mod. The output is ok, not as good as vga, the colors bleed a bit but it flickers alot less which some people may like.
    to use the av in you just need to use a lead which converts the svideo from your video card tv out to composite (single video phono plug) and then use one of those adapters that normally converts two stereo phono leads into a stereo jack plug. One side of the adapter works perfectly for putting the video through to the screen. Then you just need to force your video card to detect tv out which fortunatly in most cases is alot easier than forcing a second monitor to be detected.
  9. #89
    Nov 2003
    New Zealand
    Hi sorry to just jump in here but was I just what to ask what video cards are people using to get the hack to work with vga? .This is becouse Im look at buying a new video card to replace the onbord video (Intel 82865g) as it looks as though it will not do the scan rates and so on.
    Thake you for any info you give.
    Hy-tek
  10. #90
    Nov 2003
    UK Cheltenham
    Quote Originally Posted by hy-tek
    Hy-tek
    I use a Radeon 9600Pro , it does custom resolutions, composite sync etc, its also a great gameing card but possibly a bit overkill for a car im just running mine on my desktop pc at the moment
