Playstation LCD Hack - Works!!
Friend dropped by today and tested out some stuff on my Sony PSOne LCD, and we pulled this one off (more like he pulled it off while i was making a composite -> 3.5mm cable).
My PSOne LCD is a PAL LCD. There *is* a difference between the NTSC and PAL LCDs, the timings are not in powerstrip for the PAL Sony PSOne LCD. We obtained approximate timings from http://www.hut.fi/Misc/Electronics/c...nversion.html.
Large image 1: http://nakoruru.rudora.net/serio/lcd...hoto-large.jpg
Large image 2: http://nakoruru.rudora.net/serio/lcd...to-large-2.jpg
But it works!!! It f***ing works!!!
Testbed:
Video card: Radeon 9000 Pro, on Dual Monitor mode (else there was no way we could try the PAL timings without rebooting every time).
We found after comparing the Sony MultiAV passthrough with the input that only the SVideo Y, R, G and B lines are not directly passed through. The Video CSync pin on the MultiAV connector (pin 6) actually went straight through, which made us wonder if it was the correct pin.
Wiring:
Some of the wiring diagrams available on the web are slightly misleading:
Wire the +5V line (pin 10) to the VGA DCC to obtain 5V. When the LCD senses +5V on the +5V line, it switches on. This is some sort of sense line.
Wire VGA CSync to pin 5 (SVideo Y). This is *NOT* the same as Composite / CSync on the Sony MultiAV out.
Tell your video card to use composite sync! This hack doesn't need a resistor between VSync and HSync as it's using CSync, which is done on the video card.
Nb. Please do not try the above just yet, i'll review everything with my friend and post everything up on a website. Also note that this has only been tested on the PAL LCD, and we can't test it on a NTSC display.
By the way, the LCD photos look a little odd because it's really hard to photograph an LCD nicely..
Keep us updated!! This is VERY interesting...
Majik
Fantastic news.
Once you have double checked everything, could you post a complete wiring schematic of exactly what VGA pin goes to what pin on the LCD unit - just to remove any possible conusion?
Is there anyway we can obtain power to the LCD display from the powersupply rather than using the external supply (I want to mount my display in the front of the case).
And lastly - what if the graphics card doesn not support composite sync? I recall my geforce2 doesnt have the option anabled although my Radeon does support it.
thanks for all your hard work.
Ian
congrats man! looks good.
so did u notice a big difference in quality?
hehehe I know exactly what you mean
Keep us updated as I would like to see your pinouts using composite sync, also more pics would be good too
This afternoon i had some time, so i bought a Ti 74LS86 IC (TTL XOR IC) and built the seperate sync to composite sync circuit on this page(http://www.hut.fi/Misc/Electronics/c.../vga2rgbs.html), and connected it up through my nForce's onboard Geforce 2.
The image isn't as good as with ATi's CSync. It looks like someone ran the image through nearest neighbour filtering. I plugged the LCD into my ATi card with seperate HSync and VSync, and the image looked the same as on the onboard Geforce 2 MX...
ATi makes really nice cards... ^_^
hmmm, this would be the solution for my gamevue perhaps?
http://www.hut.fi/Misc/Electronics/circuits/sync_r.html
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
