Results 1 to 2 of 2
Thread: What GLUE? Want to BOND touchscreen to LCD
    Apr 2006
    I need a glue/silicone that is clear and UV resistant (sun will not cause it to turn yellow). Any ideas?
    I have a 3M capacitive touchscreen.
    Oct 2007
    I'd call up 3M and ask them, considering they make all sorts of adhesives to begin with. Typically I've used tape along the edges to hold it in place before it's sandwiched into an enclosure. If you were using a resistive overlay, this wouldn't be a problem. With capacitive, you've gotta be a little more careful. Their customer service should be able to point you in the right direction.
    Post what they recommend -- I'm sure others will run into this down the road.
