Results 1 to 4 of 4
Thread: Additional questions about LCDs: Is 400 nit too bright?
    May 2003
    I know I am asking alot of questions regarding LCD displays but it is one of two areas of the system that I feel that my lack of experience will hurt the project if I choose poorly. (So I am asking lots of questions to avoid that!)
    I found a 7" LCD Module that comes with everything that I need to make it work (controller, input leads) and am wondering about the specs. I am wanting to ensure that I can see the display during the day so I was told to look for monitors with a higher than 250 nit rating.
    Is 400 nit rating too high? What do you guys think of the following specs:
    Resolution (pixels): 1440 x 234
    Active Area (mm): 154.08 x 86.58
    Screen Size (Inches): 7.0" Diagonal
    Dot Pitch (mm): 0.107 x 0.370
    Color Configuration: RGB V Stripe
    Overall Size (mm): 166 x 100 x 6.79
    Backlight: "L" Shape CCFL
    Input Voltage: 5 VDC
    Contrast Ratio: 150/1
    Brightness: 400 nit
    This is for a unipac UP070W01 LCD module (The vendor that I might purchase from sells a complete kit with everything)
    Please share your experience with me. Once I get this down the other area of concern is powersupply including startup and shutdown circuit. Other than that I am ready to go.
    These forums are great but there is allot of varying opinions on the two topics that I have questions about and I am trying to narrow it down.
    Thanks in advance for all of your help!
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    if you can adjust the brightness it would work great. I have a 250nit screen and sometimes that is too bright for me at night.
    '98 Explorer Sport
    80% done
    May 2003
    I just spoke with the vendor and it looks like this screen will not work also as the operating temp is only 0C which I believe is 32F
    Looking at the manual: -http://www.datamodul.com/pdf/tft/DM%20UP070W01.pdf
    It states that I can adjust the brightness by "The brightness of LCD panel could be changed by adjusting the AC component of
    VCOM." I assume that there is some way to maybe tie this to a dimming switch or even to the cars dimmer?
    What I do not understand is the Note number one below. If I am reading correctly the lamp could not be started in temps under 25C or 77F?:
    c. Backlight driving conditions
    Parameter Symbol Min. Typ. Max. Unit Remark
    Lamp voltage VL - ( 580 ) ( 638 ) Vrms Note 3
    Lamp current IL - ( 6.5 ) ( 7 ) mArms Note 3
    Frequency FL - 60 80 kHz Note 3,4
    Lamp starting volt. VS - ( 930 ) ( 1150 ) Vrms Note 1,3,5
    - ( 1100 ) ( 1400 ) Vrms Note 2,3,5
    Note 1: Ta = 25C
    Note 2: Ta = 0C
    Note 3: Reference value, correct value is subject to final backlight specification which will be decided in the future.
    Note 4: The lamp frequency should be selected as different as possible from display horizontal synchronous signal to avoid interference.
    Note 5: For starting the backlight unit, the output voltage of DC/AC’s transformer should be larger than the maximum lamp starting voltage.
    Jul 2002
    Boston, MA
    I believe that is a problem with all the lcd's (cell phones, pda's, etc) but after your car warms up a little you should be all set.
    Oh, I forgot, How much are you getting the LCD for? any links to the vendor?
