Results 1 to 3 of 3
Thread: 619 vs 701
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    619 vs 701
    Ok, I have dug around a bit but coming up a bit dry....
    How does the Lilliput 7" EBY701-NP/C/T compare to it's older brother the 619?
    I'm asking since I came up with a old "new" one but after taking it out of it's wrapping I find that it's a bit dark even with playing with the settings and viewing in a in-door environment.
    Or am missing something here?
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Depends on when they were made.
    Both models had "old" and "new" versions.
    And, as you probably already guessed, Old = CCFL backlight, and New= LED backlight.
    The New versions both use the same exact LCD panel inside but the Old versions used 2 different LCD panels.
    Aug 2009
    SonyLand
    Thanks!
    Now I just have to check the unit for itself build date.
  1. Lilliput 619 Touchscreen Monitor
    By TeamRSX in forum LCD/Display
    Last Post: 06-23-2008, 10:22 AM
  2. Lilliput 619 Experience/Brightness
    By Paracelsus in forum LCD/Display
    Last Post: 05-04-2008, 07:54 PM
  3. Lilliput 619 Experience/Brightness
    Last Post: 05-04-2008, 07:21 PM
  4. lilliput 619 is reflective, 629 has antiglare?
    By kbyrd in forum LCD/Display
    Last Post: 06-23-2006, 07:44 AM
  5. lilliput 619 & 629 same parts?
    By xdjxklusivex in forum LCD/Display
    Last Post: 10-24-2005, 01:10 PM
