After about 8 hours searching the internet I finally gave up and this forum seamed to be the closest I could get on this subject. What I am looking to do is to connect any brand/model 14" XGA LCD display and corresponding inverter to a SBC with a 50-pin flat panel connector.
The SBC is the following model Boser HS-6237. The pinout for the 50-pin flat panel connector is as follows:
Flat panel display connector
Pin Function Pin Function
1 +12 V 2 +12 V
3 GND 4 GND
5 +3.3V or+5V 6 ENAVDD
7 ENAVEE 8 GND
9 P0 10 P1
11 P2 12 P3
13 P4 14 P5
15 P6 16 P7
17 P8 18 P9
19 P10 20 P11
21 P12 22 P13
23 P14 24 P15
25 P16 26 P17
27 P18 28 P19
29 P20 30 P21
31 P22 32 P23
33 P24 34 P25
35 SHFCLK 36 FLM
37 M 38 LP
39 GND 40 ENABKL
41 P26 42 P27
43 P28 44 P29
45 P30 46 P31
47 P32 48 P33
49 P34 50 P35
There is also flat panel display interface table in the manual. See attached picture.
Please suggest inexpensive 14" LCD/Inverter models preferrable with datasheets and cabling that I could use. Could someone suggest any guides on how to do it or provide some guru guidance? I feel like I am over my head with that project
Maybe I need to use LCD LVDS Module like LVDS-01-RS-R90 and run LCD and inverter cable from it.
http://www.mpi.ch/files/File/IEI/Boa...rd_0117-52.pdf
I just can't find any info that it will be compatible.
