Results 11 to 20 of 30
Thread: Using Arduino to Auto-dim LED EBY701?
  1. #11
    Vendor - Qube colin's Avatar
    Dec 2006
    I just meant that one example was too complicated. It has three LEDs in a crossfade. Speakin of which, where is stevey!
  2. #12
    Raw Wave
    Nov 2009
    Hopefully if he's intending to use the Arduino, he'll figure out from the linked example that the key instruction is " AnalogWrite (Pin, Val); "
    where Val is 0-255
    and Pin is a digital output.
    That example provides the code needed - just cut out (or don't connect) the other LEDs.
    As to the programming language (syntax) - don't ask me. I use assembler! (And I've only just started looking at the ATmega set.)
  3. #13
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    i've played with that code linked above and a few things to keep in mind is that around about 5% duty cycle the leds will flicker, and thats deponent on the MOSFET and leds.
    I'll go through and slim the code that i have so far to just 1 photoresistor and 1 output if you'd like it.
    another edit: dedicating a whole arduino to dimm the backlight is a bit of overkill, no? maybe somebody can point in the direction of a simple circuit that can do this....
    IDK just a random thought
  4. #14
    Raw Wave
    Nov 2009
    The flicker will be frequency - the MOSFETs & LEDs are capable of much faster switching.
    Else it's beating with lighting (eg multiples of 50 or 60 Hz).
    Decrease the cycle delay.
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I use a 12F683 for some small PWM products. It can do what you need cheaply and it's fast. The speed issue has more to to with switching the MOSFET. For example sourcing with 5V logic as a control requires transistors to open and close the gate. You can get it faster with less parts by using a TTL level MOSFET on the sink side. As far as flickering at the low end, just set a minimum you can live with.
  6. #16
    Feb 2010
    i just assumed it was it was the mosfet's i was using were slow. i started using a solidstate relay (opto-isolator -> mosfet pair) cause i am still a noob so i didnt want to risk my arduino... and i got a bunch layin around...
    sorry i fell asleep last night ill work on the code today... where is the op?
  7. #17
    Feb 2008
    I'm here, sorry, been out for a few days.
    Thanks for all the input and discussion, very cool that theres some people interested.
    Now, ... I'm unsure how the mosfet stuff works, etc... I have been playing with a little code on the web that has been pre-written for the arduino, I have seen some Photo-cell sample code and trying to link it to control the pwm outputs of my arduino, I think this should be pretty simple, I'm having a hard time putting the code together though, linking the ambient light sensor code to the pwm current output code and putting delays on, etc... so that if it goes dark, it will slowly converge to a lower current output instead of being instant, etc..
  8. #18
    Feb 2010
    // dimmer
    const int ledPin = 9; // LED output pin
    const int lightPin = 0; // Photoresitor input pin
    int lightvalue = 0;
    int output = 0;
    void setup() {
    // initialize serial communications at 9600 bps:
    Serial.begin(9600);
    void loop() {
    // read photoresitor
    lightvalue = analogRead (lightPin);
    // configure light reading to led out
    output = map (lightvalue, 0, 255, 0, 255);
    // write output value
    analogWrite (ledPin, output);
    // debug section - writes to moniter
    Serial.print ("lightvalue = ");
    Serial.print (lightvalue);
    Serial.print (" - output = ");
    Serial.println (output);
    // delay 50ms
    delay (50);
    -END- dont copy this
    most basic dimming example i can come up with. i'm still pretty new to this so maybe some one with a better eye may have suggestions, but it works pretty good. however, it may benefit from a little smoothing and i havent tested it on a led backlight cause i dont have one -yet-
    best pic i can find for the photoresistor. Vcc = 3.3v ; v = lightPin
    [Right] the first one is the i used
    [Left] the other one will reverse the relationship between input and output
    help this helps
    another edit: i used a 330 1/4 watt resister, you may also use a variable resister to trim input rather than adjusting input via code
  9. #19
    Mar 2004
    Florence Yall, BFKY
    You could also delay it a bit so it doesn't jump derectly to the input value, and probably slow it down a bunch.
    Code:
    // dimmer
    int lightvalue     = 0;
    int delayedvalue   = 0;
    int output         = 0;
    void main()
      Serial.begin(9600);
      delayedvalue = lightvalue;
      forever()
        // fade the value a bit
        if(lightvalue > delayedvalue)
          delayedvalue++;
        if(lightvalue < delayedvalue)
          delayedvalue--;
        output = map (delayedvalue, 0, 255, 0, 255);
        // Set a minimum value (i.e. 10) or use map() whatever works best
        if(output < 10)
          output = 10;
        // delay 50ms
        delay (50);
    Or averaging, which usually gives better results with ADC values
    Code:
    // dimmer
    int lightvalue[32] = {0};
    int idx            = 0;
    int output         = 0;
    void main()
      int i;
      int total;
      Serial.begin(9600);
      forever()
        lightvalue[idx++] = analogRead (lightPin);
        if(idx >= 32) idx = 0;
        // avarge the light value
        for(i = 0, total = 0; i < 32; i++) total += lightvalue[i];
        delayedvalue = total / 32;
        if(output < 10)
          output = 10;
        Serial.print ("delayed = ");
        Serial.print (delayedvalue);
        // delay 50ms
        delay (50);
  10. #20
    Feb 2010
    i have to say though that a well placed light senser and code will make a more appealing backlight than too much delay, via direct delay or averaging.
    think about it... the only time your eye will notice a change in backlight intensity is when it's different from the ambient light. Other wise, when is just about perfect, the screen will look like it's the same brightness all the time. Again i haven't tried this with a backlight, but i have noticed it with a bunch of -really- bright leds.
  1. Browse by Cover (Coverflow) - Updated 11/8/07
    By moahdib in forum RR Plugins
    Last Post: 09-20-2008, 08:51 PM
  2. Telematics.net
    By IntellaWorks in forum Software & Software Development
    Last Post: 11-05-2004, 08:20 PM
