Results 1 to 10 of 11
Thread: running two touchscreens.
    Feb 2007
    I had this figured out on my laptop before I installed everything into my car but I've hit a little snag.
    Here's what I've got: Running Windows 7 and touchkit, 7" lilliput in the center of my dash and a 7" Shark in my steering wheel. The Lillput runs to the PC via the on-board VGA chipset and the Shark is connected via a USB 2.0/VGA adapter. I've got the displays working and the pointer moves from screen to screen just fine using a mouse. I can drag applications from one screen to the next, BUT....not with the touch screens. After running the calibration on full screen, the touch panels seem to be reversed. i.e. the steering wheel screen operates the center dash screen and visa versa.
    Here's the kicker...The second monitor doesn't actually show up in the display settings. I figured the quick fix was to just check mark the "Extend display to this monitor" option but when I got into the control panel...the monitor wasn't there?
    ideas?
    Vendor - Qube colin's Avatar
    Dec 2006
    Drivers?
    Feb 2007
    as in reinstall? Or as in which one am I using?
    I was just on my way down to the garage to reinstall this driver
    here's the file in question.
    EDIT: I'm running the latest version of touchkit.
    Dec 2006
    Reinstall. If it doesn't show up as a second screen then check your video drivers in the first place.
    Feb 2007
    will do...I'll report back.
    Low Bitrate majasticmoose's Avatar
    Dec 2009
    You can also press win + P on Windows 7 and it will toggle multiple monitors.
    Andrew
    Feb 2007
    Quote Originally Posted by majasticmoose View Post
    Andrew
    yup...but that only works with the display. The displays were fine (oddly enough). It was just the touchscreens that weren't working.
    On that note...I did get it working. I was full out retarded for about 5 hours before I realized you had to actually SELECT the damn touchscreen controller you wanted to go with whatever monitor.... turns out it was working just fine in the first place. What can I say...I'm a noob.
    Dec 2006
    hahahaha well at least you got it workin right?
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls
    Quote Originally Posted by cbevis View Post
    Can you tell me how you went about picking the controller, then setting it up? I have been trying this for a couple hours today and just can't seem to get it to work for me.
    Cheers,
    John
    ZOTAC G43ITX-A-E 2.5ghz Dual Core Celeron 2GB 160GB SSD
    Win7 Ultimate - Remote Starter - Directed HD - Wifi
    Garmin Mobile + MS GPS Puck - LTE WiFi Hotspot
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
    Jan 2008
    you need to go to the "installed touchscreen controllers" page. click on the monitor mapping-- it will allow you to specify which driver/touch screen is associated with which display.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. Running Multiple Touchscreens
    By tschallb in forum LCD/Display
    Last Post: 03-03-2008, 07:27 PM
  2. Replies: 4
    Last Post: 02-05-2008, 12:20 PM
  3. Creating a Module to View another program already running
    By Apache_Pilot in forum DigitalMods (Scripts / API)
    Last Post: 01-19-2008, 08:15 PM
  4. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  5. Replies: 23
    Last Post: 03-21-2005, 03:45 AM
