Results 1 to 4 of 4
Thread: KS0066 LCD and programming - What platform?
    May 2006
    Perth, Australia
    I've been out of this forum for a few years now, but I've recently been getting into the more complicated side of things, and want to start learning a platform.
    To be more specific, I want to build a basic multifunction alphanumeric display that can display different information from various vehicle sensors. My vehicle (1994 Nissan Terrano/Pathfinder w/ TD27T engine and auto transmission) is pre-OBDII, and I'm fairly sure doesn't use any standard diagnosis system.
    I want something that can display the following information for me;
    Pre/Post IC Boost Pressure - voltage/resistance based sensor
    Pre/Post IC Charge air temp - voltage/resistance
    Pre/Post Turbo EGT - voltage/resistance
    Water Temp - voltage/resistance
    Fuel level (twin tanks) - voltage/resistance
    On-board air tank pressure - voltage/resistance
    (I'm beginning to see a recurring theme)
    I may also want to input frequency (speed/engine speed)
    Etc...
    So I need to learn a programming language to drive a KS0066 LCD display.
    What's going to be the most effective for me to learn?
    PIC/PICAXE?
    ARDUINO?
    EPROM?
    etc...
    I did Visual Basic programming way back in school, but can barely remember any of that anyway.
    Can anyone point me in the right direction?
    Cheers.
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    I would recomend that you get some kind of evaluation kit with an alpha numeric panel onboard that fits your need.
    Best thing then is to look through the examples on how to write C code for that display.
    You then need to interface your sensors and maybe some control buttons, and that is a different story...
    May 2006
    Perth, Australia
    Okay, so it looks like I need an Arduino board, a multiplexer board, and an LCD module, and will have to start from there.
    The multiplexer I need is out of stock everywhere though. It's a matrix of something like 48I/O.
    Sep 2005
    I was thinking more on the line of this http://www.olimex.com/dev/pic-mt-usb.html
    Maybe I just do not understand your project.
    Anyway. I guess you are on the go now.
  1. Haier 7" LCD TV TFT Black KXT7020 RB - $60 shipped
    By dvsdimsum in forum LCD/Display
    Last Post: 11-07-2007, 01:46 PM
  2. Replies: 0
    Last Post: 07-03-2007, 02:04 PM
  3. Good article on programming an LCD with .NET 2.0
    By SFiorito in forum Software & Software Development
    Last Post: 05-20-2005, 06:06 PM
  4. batch file programming LCD's
    By mosh in forum LCD/Display
    Last Post: 05-19-2002, 01:55 AM
  5. Control LCD with C
    By nir_vana in forum Software & Software Development
    Last Post: 10-05-2001, 10:13 PM
