Results 1 to 5 of 5
Thread: This works (?)
    Sep 2010
    This works (?)
    hi everyone. Im from argentina. Here car pcs are not so common. So its kind of difficult to find some motorized in dash screen. I found this one http://articulo.mercadolibre.com.ar/...ock-pasivo-_JM
    The name is Procars Pcin90 In. And the only data that the saler gives is:
    7" touchscreen tft lcd in dash monitor
    16:9 screen display
    tv system: pal / ntsc
    game speaker calendar input
    funcionamiento full con control remoto
    peso: 1.8 kg
    1 salida y 2 entradas de audio
    1 entrada de video
    1 salida de camara
    1 entrada auxiliar
    rca cables
    manual
    I wanted to know if this is useful for a car pc. If this can be plug and play in a computer as a monitor.
    Thank you all...
    Jan 2008
    while you can make it work, it would take other equipment..
    the unit does not accept a vga, dvi, or hdmi signal, and also does not have a touchscreen..
    Sep 2010
    Wait, It is touch screen. Its says there. I wanted to know if i could plug it to pc and make it work. I dont know maybe with converters.
    Thank you.
    Jan 2008
    the touchscreen needs to have a com port(DB-9) connection, or usb connection for the touchscreen to interface with the computer.
    if it doesn't have that, you 'could' hack a computer touch screen into it-- but this could prove to cost more time and money then a computer-specific alternative..
    if you do decide to get this, keep in mind that you will need a vga-to-composite converter-- that will also add to the cost of the screen..
    Elsewhere
    You know...
    There is a FAQ all about this....
    How about the Wiki?
  1. updated config for e815 (MOSTLY everything works!!!!)
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 06-22-2006, 04:00 PM
  2. Lilliput Touchscreen only works sometimes
    By XeroDSM in forum LCD/Display
    Last Post: 08-26-2004, 06:25 PM
  3. sound card works fine with mp3s, not with divx, why?
    By lstrunk in forum General Hardware Discussion
    Last Post: 08-04-2004, 12:06 AM
  4. Woooohooooo !!!!! XM Hibernate/Standby Works !
    By frodobaggins in forum FrodoPlayer
    Last Post: 07-27-2004, 11:33 AM
  5. Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!)
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 02-14-2002, 05:05 PM
