Results 1 to 10 of 16
Like Tree1Likes
Thread: Need help powering this Screen
    Sep 2010
    Unhappy Need help powering this Screen
    Hi all, I used to post here in highschool, god knows what my username was....
    Anyway, I recently got a screen for $100, which is a steal here in Australia (normally around $250 after shipping).
    The catch is it doesnt have a wiring loom for the power.
    http://img.alibaba.com/photo/2691940...PC-monitor.jpg
    That is the screen. It used to be very common so hopefully someone can tell me the pinout for the power connector.
    Thanks all, I really appreciate any help.
    Elsewhere
    Specs would help....
    How about the Wiki?
    Sep 2010
    specs?
    It has no writing whatsoever on the outside.
    Its a 7" single din motorized touch screen.
    The only non-schematic writing on the mainboard is "po7oia-M"
    It has VGA, 2 Composite, and a USB input. It also has a remote IR reciever on the front, but thats on a daughter board so I dont know if its actually active.
    The board has a spot for a TV tuner which is not installed.
    http://www.aliexpress.com/product-gs...olesalers.html
    Thats about all I can tell you.
    Jan 2008
    it looks like the old thermaltake motorized screens..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Sep 2010
    :O
    you're right!
    http://www.thermaltakeusa.com/Produc...C=1257&ID=1481
    Its identical to one of those but no branding on it.
    Assume its the same internals too? Anyone have the pinout for the power for these>?
    Elsewhere
    Did you even bother to read the specs in the link you provided?
    It specifies the power requirements right there.
    How about the Wiki?
    Sep 2010
    Yeah, but not into which pin. Its a 6 pin connector. I dont wanna put positive into the ground.
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    It looks like only 3 pins are populated in the 6 pin power cable shown in the user's manual. (on thermaltake's site for the a2314)
    Should be top 2 from left to right, and bottom 1 left.
    (It was a bw pic, so I couldn't say for sure what was hot, but my guess was pins 1,3)
    If you have a DVOM, you can check the pins for continuity to the chassis, thereby locating ground. The other(s) will be 12v DC.
    Sep 2010
    I dont unfortunately, otherwise I would have checked.
    I know most of the theory just dont hav the tools.
    Someone on here MUST own a thermaltake screen (or one of these clones)
    May 2010
    Detroit, MI
    OK, well like they say, you can't help those who won't help themselves.
    I would suggest picking up a cheapo meter. They can be had for less than 10.00.
  1. Powering Touch Screen from 12V rails on PSU
    By jellymonster in forum LCD/Display
    Last Post: 06-02-2009, 11:41 AM
  2. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 05:29 PM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 12:23 PM
  4. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 10:56 AM
  5. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 06:06 AM
