Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Lilliput 629 LED, Blacks out for a second when braking?
  1. #11
    Apr 2006
    Sydney, Australia
    @ Danny - car to answer the relay portion?
  2. #12
    Dec 2010
    I also have this problem. Anyone know how a diode could cure the problem?
  3. #13
    Jan 2008
    just reposting the 2 possible solutions for others to locate from dodgecharger's other thread:
    1. reverse camera issue:
    the easiest solutions are these:
    1a. a relay-- this would prevent small voltages from tripping the relay, which would prevent the screen from switching. shifting between gears could still cause it to switch though-- as you usually need to cycle past reverse to get to drive(if you drive a stick, then ignore this)..
    1b. a delay, like the 528t pulse timer might be the best option-- assuming that it is only a small voltage that passes through the reverse wire(small enough to not trigger a relay). setting the timer for about a 1 second delay would prevent gearshifts from triggering the switch, while still working correctly when you stay in reverse. this would add 1second to the amount of time it would take to see the reverse image though..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. Hardware Review: Lilliput 669GL-70NP/C/T 7" HDMI Monitor
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 04-26-2010, 10:05 AM
  2. Would a Lilliput 629 run my battery down?
    By jac1502 in forum LCD/Display
    Last Post: 11-14-2009, 11:50 AM
  3. Lilliput 701 or 629
    By reedler in forum LCD/Display
    Last Post: 09-27-2009, 09:38 PM
  4. touch reversed on lilliput 629?
    By ZEEBEES in forum LCD/Display
    Last Post: 10-23-2008, 10:53 AM
  5. Lilliput 629 input problem
    By mjo151 in forum Input Devices
    Last Post: 09-12-2008, 08:59 PM
