Results 1 to 5 of 5
Thread: 4:3 vs 16:9...
    Aug 2010
    Seattle, Washington (USA)
    4:3 vs 16:9...
    I'm looking for a 10" to 12" screen, and my final decision is whether to go with a 4:3 or a 16:9 screen. I have made a short list of options for each type. A 16:9 would look better, in my opinion, with the way it is being installed (in a 2007 BMW X3). That isn't enough to convince me yet, though. For those of you with such monitors, why did you choose the aspect ratio you have? Can you think of any real advantages or disadvantages to your choice?
    Thanks guys. Hopefully I'll be able to finally pick a monitor after this.
    Elsewhere
    FYI - the widescreen monitors that are commonly used (such as the 7" Lilliput and Xenarc models, as well as other no-name 7" models) are not 16:9 aspect ratio.
    They are a 10:6 aspect ratio with an optimal resolution of 800x480.
    How about the Wiki?
    Aug 2010
    Thanks. I'll keep an eye on the actual aspect ratio of the monitors I look at.
    Any comments or opinions on whether to go with a 4:3 or widescreen monitor?
    Jan 2008
    i prefer widescreen monitors, mostly because in most cases, installing something wider is less of a issue then installing something taller.
    and there is also more screen real estate with a larger screen monitor, that can make pressing buttons easier, depending on how the buttons your pressing are designed..
    Aug 2010
    Quote Originally Posted by soundman98 View Post
    In my position, it will be just as easy to install a widescreen monitor as for a non-widescreen monitor, but I do see your point.
    I think what I'll do is take a shot of the frontend I'm developing, print it, and put that on a piece of cardboard the dimensions of both screens. I'll put it in the basic position in the car and see how it feels.
    Thanks for your thoughts.
  1. would you go 7" (16:9) or 8" (4:3)?
    By 3l33tPhantom in forum LCD/Display
    Last Post: 08-25-2009, 06:11 PM
  2. 4:3 vs. 16:9
    By Devious12345 in forum LCD/Display
    Last Post: 05-19-2008, 06:15 PM
  3. Adjusting screen size for video (4:3, 16:9)
    By lookinco in forum StreetDeck
    Last Post: 09-28-2006, 04:34 AM
  4. 4:3 & 16:9
    By wizz in forum RR Bug Tracker
    Last Post: 03-25-2005, 05:15 AM
