Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Lilliput 669GL-70NP Extending HDMI Cable
    Constant Bitrate cla1067's Avatar
    Apr 2009
    Sarasota, FL
    the 669 has the usb and hdmi cable combined, so it goes from Hdmi to hdmi-usb. Would it be possible to plug a normal hdmi cable up to the monitor then plug there hdmi-usb cable up to that, so you could still use the touch screen?
    HDMI Cable --> Adapter --> hdmi-usb cable
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    you can use a HDMI extension cord and it'll work just fine. Monoprice sells them for pretty cheap
    Live mp3Car Facebook Chat
    Apr 2009
    Sarasota, FL
    Thanks I wasn't sure if they did something special to the hdmi-usb cable they have included and I'll check out that site.
    Nov 2010
    Fredericksburg, VA
    I've already ran my HDMI and USB cables in my truck with a USB hub in the dash. can i just a USB cable to the hub or do i have to use the hybrid cable?
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by dethbyoogabooga View Post
    not quite sure what you mean. If you have seperate HDMI and usb cables it wont work, as the HDMI/USB cable that comes with the 669 combines to HDMI when connected to the monitor.
    Apr 2008
    Ballarat, Australia
    A cheaper solution you may want to consider is running HDMI over CAT5.
    In my new project I'll be running HDMI and 2 USB lines over 2 CAT5 cables. Means everything is nicely shielded and a buttload cheaper than shielded HDMI and USB extension cables.
    2004 HSV Clubsport M6
    Gear: i3 4130T, 8GB DDR3, ASRock Z87E-ITX, Noctua cooler, PicoPSU 150W, OpenUPS + SLA battery, 2DIN Samsung 7" screen with ITX enclosure, Win8 64 Pro
    Progress: [||||||| ] 80% - Planning done, Parts aqcuired, Benchtesting at 50%
    Apr 2009
    Sarasota, FL
    I don't know the hdmi cables are pretty cheap:
    http://www.monoprice.com/products/su...=10240#1024010
    Apr 2008
    Ballarat, Australia
    Quote Originally Posted by cla1067 View Post
    Cat5e usually goes for about 50cents a metre (in Aus, which is actually the same in the US at the moment). For HDMI I would go for Cat6 which is a bit more expensive.
    The benefit to Cat5/6 is you can run exactly as much as you need and it can actually carry a variety of different stuff. In the case of the USB/HDMI comb lilliput use, you could easily extend that using cat6.
    Jan 2008
    i don't think it is cheaper to use cat5-- as cla1067 posted, mono-price is really cheap for cables-- even a 40foot hdmi is only $25.. a brief search shows that hdmi-to-cat5 converters are $80/pr....
    Jan 2005
    You should be fine with an extension. I have a monoprice right angle adapter on mine, and everything works.
    What resolution are you running the 669GL at? I'm having some troubles with mine... I posted about them in another thread.
  1. Lilliput HDMI screen that would fit in 629 casing?
    By Archy88 in forum LCD/Display
    Last Post: 11-06-2010, 03:11 PM
  2. SKS Cable Extension for Lilliput Monitor
    By kbento in forum LCD/Display
    Last Post: 08-20-2009, 08:45 PM
  3. Ordering replacement lilliput ribbon cable
    By FLESIK in forum LCD/Display
    Last Post: 07-03-2006, 11:58 PM
  4. Lilliput 9pin mini-din USB VGA cable
    By Pale Rider in forum LCD/Display
    Last Post: 10-28-2005, 01:54 PM
  5. Lilliput cable not long enough
    By Felipebras in forum LCD/Display
    Last Post: 07-22-2005, 05:00 PM
