Results 21 to 30 of 35
Thread: epia tv out quality
  1. #21
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Originally posted by MadDog UK
    How the hell did you get that in your car:-) Does it have a motorised housing???
    Heh no, my PC duals as a Car PC and set top DivX/MP3/Internet box.
  2. #22
    Constant Bitrate leenas's Avatar
    May 2003
    So with 848x480 the screen is the exact fit for the 7 inch screen you can get from digitalww?
    If so then seals the deal...now just gotta wait for the $$
  3. #23
    Jul 2002
    Boston, MA
    has any one tried this with the M10000?
  4. #24
    May 2003
    Austin, TX
    I can't imagine it would be any different. I believe it's the exact same video card...
    - Taylor
  5. #25
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    I am hoping that there is some way of doing this with the Eden 800. I have tried a few tricks that have worked with other cards in the past but they have all failed. By the looks of things the linux bods have replaced the video driver completely and now have widescreen capability so the hardware itself is capable.
    Come on Via sort it out
  6. #26
    vbi
    vbi is offline
    May 2003
    Caput Mundi
    I have an Epia M 10000 and a digitalww TM701L.
    It's a pity I cannot use that resolution with mediaengine.
    Ermanno vbi
    TM701L with TouchScreen, Epia M10k, 80Gb 3,5" Hdd, DC-DC PS.
    System up and running with GPS and Bluetooth...
    Writing software for a Parallel port relay controller.
  7. #27
    Mar 2003
    UK
    Why?
    There are several schemes for media engine that are widescreen but I agree that these aren't 848x480. I presume that you don't want to design one yourself then?
  8. #28
    Mar 2003
    UK
    Sorry misread that thought it said media-box
  9. #29
    Mar 2003
    UK
    BTW - I have had this link for adding widescreen to radeon chipset cards for quite a while
    http://www.dtvmax.com/radeon_guide.htm
    and have just found out that the section labelled Unlocking Additional Display Resolutions by Windows Registry Modifications works on my Rage Mobility chipset in my laptop under W2k
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\ati2mpab\Device0]
    "DALNonStandardModesBCD"=hex:12,80,07,20,00,00,00, 60,08,48,04,80,00,00,00,60,\
    14,00,10,50,00,00,00,00,12,80,06,00,00,00,00,00,10 ,24,05,12,00,00,00,00,08,\
    00,05,12,00,00,00,00,10,24,06,00,00,00
    Now have a laptop that can output
    720x480, 848x480,1280x720,1400x1050,1280x600,1024x512,800x5 12 & 1024x600.
    If this all works in the car then I may well just get a v.cheap pci card and forget about trying to get the Eden800 chipset to work.
    The reason I'd never tried it before now is that PowerStrip 3.3 says that advance timings are not supported (greyed out) and hence it didn't occur to me that windows hacks might still work.
  10. #30
    Oct 2002
    Alaska
    on your EPIA do you guys set overscan or underscan in the BIOS?
    And with my EPIA when I try to stretch the screen to fit the widescreen, the the right and left sides of the desktop gets cut off, so Media engine doesn't look right. And when you dont stretch it there is a almost 1/2'' space arround all sides of the picture.
    The widescreen resolutions won't work in media engine, so what do I do!! I was able to get the image PERFECT right up to the edge with my geforce4, but it wont work with this EPIA tv-out.. any tips/?
