Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: epia tv out quality
    Aug 2002
    Dallas - Tx
    epia tv out quality
    OK i have an epia m9000 using the composite out to an lcd that has a 2400 x 480 resolution and 250nit the quality im getting is absolutly horrible. I mean I dont expect to be vga quality but even at 640x480 you can barely read the text. I am curious if this is just because the tv out thats on board sucks or possibly something else I need to look into. Ive thought about picking up a matrox dual head card as everyone seems to say that the video out on these cards is great.
    Any suggestions...
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    If I'm correct you LCD resolution is really 800 x RGB x 480. Or simply put 800x480.
    Text will be unreadable unless you increase the font size. Running at 640x480 will make it more readable, but you will still need to increase the font size. This is the major down side to TV-out.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    If you want to get a card with tv out, I have always recommended ATI's they are great for TV use.
    Aug 2002
    Dallas - Tx
    I guess I will check into the ati/matrox cards see what kind of results I get. I hooked up my lcd to the tv-out on my compaq laptop and at 640x480 standard font it was much much better, easier to read.
    I just have a feeling that the tv out on the epia blows as to be expected so far this board has sucked beyond what I thought it would. Dvd barely works and the only plus that I have see from it so far is that it dosent generate much heat.
    May be putting this up for sale soon as I just dont feel its going to meet my needs.
    Newbie Mikey's Avatar
    May 2003
    Canada
    id even recomend Asus TV out cards also. ive owned a few of them and my asus GF2 is better than my chaintek 4600
    Newbie phoTToniq's Avatar
    Mar 2003
    London
    dvd should work great. Make sure you are using PowerDVD (the only windows dvd player capable of taking advantage of the EPIA on board hardware dvd decoder) and make sure that you have the hardware acceleration turned on in the PowerDVD software too.
    See http://www.mini-itx.com/reviews/nehemiah/?page=12#s25 for more detailed info - it should work fine.
    The Via graphics processor on the mobo is not cabale of outputing to widescreen formats by the way...
    phoTToniq.
    Jan 2003
    Ruston, LA
    phoTToniq.
    That's not exactly true, it can display 848x480. Just not on the TV-Out.
    vga only
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    vbi
    vbi is offline
    May 2003
    Caput Mundi
    My Epia M display 848x480 on the TV out and is the perfect resolution for a 7" 16:9 screen.
    Ermanno vbi
    TM701L with TouchScreen, Epia M10k, 80Gb 3,5" Hdd, DC-DC PS.
    System up and running with GPS and Bluetooth...
    Writing software for a Parallel port relay controller.
    Mar 2003
    London
    WOW - really? So it can display widescreen? Damn - this is what had been putting me off of buying one.
    Now i just need to clarify whether it can do it on the TV out as well as the VGA port..
    Aug 2002
    Dallas - Tx
    Yea Ill have to look into that to becaue I dont think i saw that as an option for the resolution. I just set it to 640x480 and use the display drivers to stretech the width, it scoots it over just a little to much but it does take up the whole screen. With myHTPC the way everything is layed out it looks good.
    I played around with the contrast/brightness on the screen along with the tv out settings and got it to a point where it does not look washed out anymore.
    As much as I like media engine the way its layed out and the text is just not clear enough for tv-out quality even if it was designed for it compared to the setup in myHTPC.
