Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 60
Thread: Almost everything you wanted to know about the Lilliput 669GL
  1. #11
    Vendor - Mo-Co-So
    Nov 2005
    Trip
    Yes it will, but just like the frame you need to use the HDMI adapter for the video if you are using it. There is also a new version of the 669 "H" bracket that we are now shipping. I dont have the pics up yet. It simplifies the conversion process to a degree.
  2. #12
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by theonlykid View Post
    link plz .
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  3. #13
    Apr 2006
    Sydney, Australia
    i got the 629 Bybyte double DIN frame thinking it would fit the 669, but sadly it doesnt.
    The frame arrive from the mp3store, i guess i missed where it said it doesn't fit the 669 cause the pix were identical!
    Did i mention i have the 5 wire version
    New Car PC Build list in progress
  4. #14
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by Kosti View Post
    I have the 5 wire, and I made the same mistake. I emailed Bybyte and asked them if there were going to make a double din frame for the 5 wire version, and they told me the 5 wire is too big for double din - which means it just isn't going to happen.
  5. #15
    Vendor - Mo-Co-So
    Nov 2005
    Trip:
    A pic of the new aluminum 669 “H” bracket is here.
    And a link to the product on Ebay and our site
    We also have 5M/16’ HDMI to HDMI cables for the 669 that can be found here. They have the touch built in, via USB, like the stock cable
  6. #16
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by kegobeer View Post
    yeah it's annoying, how freaking hard is it to make it a touch larger to fit the screen, its a 7in so cmon!!
    sounds to me they have $h1t loads of stock of the old, hence the push to not make the 5w version
  7. #17
    Vendor - Mo-Co-So
    Nov 2005
    Do you have any idea what you are talking about? Do you know how much it is for a new mould? Do you realize that if you make it bigger there will be additional problems with it fitting in double din dash kits? I dont blame David/Bybyte one bit for not doing it.
    How hard would it be for Lilliput to change the size of the touch panel on the 5 wire version?
  8. #18
    Nov 2010
    Panama City Beach
    I don't agree, and I hope my previous post didn't lead anyone to believe that I think Bybyte is to blame. I think Lilliput is to blame here. They must have known that their monitors are hacked and used in carpc applications, and to change the panel size seems pretty dumb to me.
    There are other ways to get the monitor on the dash. I whipped up a bracket for my 99 Grand Marquis that included some scrap metal, a block of wood, and the little nut that came with the included stand. It still looks like a monitor, and I had to mount the monitor to the wood, then bolt the wood in from the rear of the instrument cluster finish panel (what a pain in the butt), but it's where my head unit used to be, it's rock solid, and looks pretty darned good until I get around to following one of the awesome fabrication threads and I make my own custom bezel. It would be nice to have a double-din frame, but since the panel is too big for it there's no sense in yelling at Bybyte about it.
    Speaking of a custom bezel, when do you think you'll have the 669 five wire front housing available, Chris?
  9. #19
    Vendor - Mo-Co-So
    Nov 2005
    Just to be clear the issue with the Bybyte double DIN frame and the 5 wire 669 is that the touch panel is larger then the LCD panel. The LCD panel in the 5 wire HB is exactly the same size as every other 7" panel they use. It is absolutely a problem that Lilliput can fix if they want to.
  10. #20
    Apr 2006
    Sydney, Australia
    I also agree the Bybyte frame is freaking awesome, jut not suited for all 7in models and i found out the hard way. Not blaming anyone, just sucx
    The glass TSplanel on front of the screen is the problem of fitting into these items which seems to have been designed around the 619/629. [This is my opinion as i am not sure what was the prototype used by ByByte] nor do i have the knowledge of the building of the product that you may have with the owners as a reseller
    As from what I can see its The H bracket that was added to hold the control board of the 669 as I see no other difference especially when it was ordered online both diagrams are identical.
    So to me it appears that only one version was made not 2 version of frames (i could be wrong)
    For my application and a few front bezels, It wouldn't make much of a difference it in the size at all it looks to be only a millimeter or 2 larger although I've not measured this to be precise and the ribbon cable location is also difference.
  1. Lilliput 669GL 7" vs. Xenarc 1020TSV 10.2" (or 8" model)
    By doncarbone in forum MP3Car Products - store.mp3car.com
    Last Post: 11-01-2010, 10:47 PM
  2. Wanted, plastic buttons for Lilliput 619
    By Cret in forum Classifieds
    Last Post: 02-11-2009, 07:10 AM
  3. Wanted : VGA ribboncable for Lilliput 619GL-70NP/C/T
    By gyro in forum Classified Archive
    Last Post: 08-16-2005, 03:31 PM
  4. Wanted 7" Lilliput VGA
    By romeov in forum Classified Archive
    Last Post: 06-30-2005, 09:49 PM
  5. Wanted: Lilliput 8" Housing, case
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 03-13-2005, 11:27 AM
