I just found out mine is actually the 629 (not the 669...). I was able to set the Power State to 2 though. Do you know if this H-Bracket also applies to the 629?
that bracket looks much much better then the one I have got. mine it's bending up when I tighten the 4 screws.
I got mine from Bybyte already in the frame and didn't know about the auto on feature then. How do I get into the hidden menu when it's already pulled apart and mounted in the frame?
There is one problem with that function:
Monitor turns On when it got power, and shows HDMI source, but! when OS loading, in setting of display (video card NVIDIA) i see that monitor is DVI. If I change source for circle to HDMI again it goes to HDMI.
I maded the device, that turns on power on monitor after 15 seconds, from the moment when PC turns on, but that did not helped.
I tryed to turn on power earlier than PC, the situation is the same.
On the other hand, when i turned Off "auto powered on" function, and turn monitor manually On in the same 15 sec or othe time, HDMI mode is OK, OS tells that this is HDMI Monitor.
May be there is some error in switching DVI-HDMI code in monitor? Do you have any firmware?
sorry for my bad English.
There is one problem with that "auto powered on" function:
Is there any option to mount the 5-wire 7" into a double din frame? (669GL-70NP/C/T-HB-RV)
I also mistakenly bought the newest thinking it ad the best picture and brightness, but now see from the research that I can't mount it? Haven't even opened the box yet...
Lee
it this a 4 or 5 wire version:
https://store.mp3car.com/ProductDeta...ctCode=MON-052
Hi guys,
I've just bought the 5 wire 669 monitor.
Unfortunately, the display seems to be just a little bigger (2-3 millimeters) than the hole in the dash.
So, my question is this: is there any way to adjust the size of the image displayed on the screen and also to change the V and H position of the image in order to center it to the hole i have in my car's dash?
Thank you for your support.
