Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: Almost everything you wanted to know about the Lilliput 669GL
  1. #21
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by theonlykid View Post
    Trip:
    A pic of the new aluminum 669 H bracket is here.
    And a link to the product on Ebay and our site
    We also have 5M/16 HDMI to HDMI cables for the 669 that can be found here. They have the touch built in, via USB, like the stock cable
    I just found out mine is actually the 629 (not the 669...). I was able to set the Power State to 2 though. Do you know if this H-Bracket also applies to the 629?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  2. #22
    Constant Bitrate tibimakai's Avatar
    Feb 2005
    San Pedro, USA
    that bracket looks much much better then the one I have got. mine it's bending up when I tighten the 4 screws.
  3. #23
    Jun 2010
    Brisbane, Australia
    I got mine from Bybyte already in the frame and didn't know about the auto on feature then. How do I get into the hidden menu when it's already pulled apart and mounted in the frame?
  4. #24
    Jan 2008
    Quote Originally Posted by tripzero View Post
    no it should not. the 669 uses the metal adapter plate to mount to the old plastic mounting plate that is compatible with the 701/629.
  5. #25
    Apr 2011
    Auto Power On
    There is one problem with that function:
    Monitor turns On when it got power, and shows HDMI source, but! when OS loading, in setting of display (video card NVIDIA) i see that monitor is DVI. If I change source for circle to HDMI again it goes to HDMI.
    I maded the device, that turns on power on monitor after 15 seconds, from the moment when PC turns on, but that did not helped.
    I tryed to turn on power earlier than PC, the situation is the same.
    On the other hand, when i turned Off "auto powered on" function, and turn monitor manually On in the same 15 sec or othe time, HDMI mode is OK, OS tells that this is HDMI Monitor.
    May be there is some error in switching DVI-HDMI code in monitor? Do you have any firmware?
    sorry for my bad English.
  6. #26
    Apr 2011
    There is one problem with that "auto powered on" function:
  7. #27
    Newbie leeman01's Avatar
    Aug 2008
    Pikeville, North Carolina, United States
    Is there any option to mount the 5-wire 7" into a double din frame? (669GL-70NP/C/T-HB-RV)
    I also mistakenly bought the newest thinking it ad the best picture and brightness, but now see from the research that I can't mount it? Haven't even opened the box yet...
    Lee
  8. #28
    May 2007
  9. #29
    May 2011
    Hi guys,
    I've just bought the 5 wire 669 monitor.
    Unfortunately, the display seems to be just a little bigger (2-3 millimeters) than the hole in the dash.
    So, my question is this: is there any way to adjust the size of the image displayed on the screen and also to change the V and H position of the image in order to center it to the hole i have in my car's dash?
    Thank you for your support.
  10. #30
    May 2008
    Bend, OR
    will the 669 H-bracket you list on ebay work with the bybyte double-din case as well as the frame?
    I'm wondering the same, I'd like the high brightness 4 wire in the enclosure so I don't have a computer under the seat.
  1. Lilliput 669GL 7" vs. Xenarc 1020TSV 10.2" (or 8" model)
    By doncarbone in forum MP3Car Products - store.mp3car.com
    Last Post: 11-01-2010, 10:47 PM
  2. Wanted, plastic buttons for Lilliput 619
    By Cret in forum Classifieds
    Last Post: 02-11-2009, 07:10 AM
  3. Wanted : VGA ribboncable for Lilliput 619GL-70NP/C/T
    By gyro in forum Classified Archive
    Last Post: 08-16-2005, 03:31 PM
  4. Wanted 7" Lilliput VGA
    By romeov in forum Classified Archive
    Last Post: 06-30-2005, 09:49 PM
  5. Wanted: Lilliput 8" Housing, case
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 03-13-2005, 11:27 AM
