Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 59
Thread: Almost everything you wanted to know about the Lilliput 669GL
  1. #31
    Jan 2008
    it should work, as the front bezel is the exact same design on both the case and frame. the biggest difference is because of the add-on plate, the main lcd board will be a couple of mm back into the housing. while it doesn't seem like much, there isn't much room in the case to begin with...
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  2. #32
    Vendor - Mo-Co-So
    Nov 2005
    Yes the 669 H bracket will work with the BBN case.
  3. #33
    Apr 2011
    I just got the bracket for the 669, and I can't quite get it to fit. The metal part that screws onto the H bracket hit the floor of the case, preventing the board from attaching. In addition, the board is taller than the enclosure, so the only way that I found to mount the board was to wedge it behind the screen before the bezel ends.
  4. #34
    Mar 2010
    Hi,
    I just got the new Bybyte frame for the Lilliput 669 that comes with the aluminum "H" bracket.
    I can't figure out how to attach the bracket to the control board. It has no screw holes just risers.
    Am I missing something? Am I just supposed to bent the metal to hold the board?
  5. #35
    Jan 2008
    Quote Originally Posted by phantomfsoc View Post
    yes-- there are some small 'prongs' that will line up with 4 of the screw holes that need to be bent over.
    HID retro--100%
  6. #36
    May 2011
    Is there a way, self mod or extension cable to mount the control panel on the dash away from the screen?
    Not really fussed about the remote, got enough of them in the house
  7. #37
    May 2011
    ok no ideas??
    How about wiring up my lilliput to my PC, the ATX cable that comes with the case is connected to the M2- ATX then on the motherboard side i have a spare floppy disc connection, can i wire the screen directly to this(yellow and black)?
    Jan 2008
    Quote Originally Posted by infinateflea View Post
    i believe it should be possible, though, i don't remember anyone trying it..
    ok no ideas??
    yes, that would be fine.
    HID retro--100%
  9. #39
    May 2011
    hi,
    Got my lilliput connected to the PC with the VGA cable, when PC turns on it goes straight to the HDMI source screen, by the time i ve dug around for the remote its switched off, how can i change it to default VGA/PC screen on start up?
    Cheers
  10. #40
    May 2011
    ok, spose the title is 'almost' everything you wanted to know.....
  1. Lilliput 669GL 7" vs. Xenarc 1020TSV 10.2" (or 8" model)
    By doncarbone in forum MP3Car Products - store.mp3car.com
    Last Post: 11-01-2010, 09:47 PM
  2. Wanted, plastic buttons for Lilliput 619
    By Cret in forum Classifieds
    Last Post: 02-11-2009, 06:10 AM
  3. Wanted : VGA ribboncable for Lilliput 619GL-70NP/C/T
    By gyro in forum Classified Archive
    Last Post: 08-16-2005, 02:31 PM
  4. Wanted 7" Lilliput VGA
    By romeov in forum Classified Archive
    Last Post: 06-30-2005, 08:49 PM
  5. Wanted: Lilliput 8" Housing, case
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 03-13-2005, 10:27 AM
