Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: Almost everything you wanted to know about the Lilliput 669GL
  1. #51
    May 2011
    Quote Originally Posted by tbassuva View Post
    Just to update anyone else who uses an HDMI connection with the 669GL, there is significant overscan when using the input labeled 'HDMI' on the 669GL, so much so that using Windows is difficult since many clicks need to occur at the edges. There is a simple fix, however, you just need to change the input to 'DVI'. The 'DVI' input does not overscan, and works perfectly fine using the HDMI connectors. For reference, the VGA input 'PC' does not overscan either. I haven't tested the composite video inputs.
    This worked for me trying to get 800x480. Thank you.
    I case any1 is wondering, I am using AT5IONT-I (not deluxe). got it working without PowerStrip of anything, just installed nvidia driver and used it to create a custom resolution.
  2. #52
    Apr 2012
    Quote Originally Posted by infinateflea View Post
    hi,
    Got my lilliput connected to the PC with the VGA cable, when PC turns on it goes straight to the HDMI source screen, by the time i ve dug around for the remote its switched off, how can i change it to default VGA/PC screen on start up?
    Cheers
    it sounds like you have the def source set to hdmi in the advanced settings there should be def source setting to have it on or off and if on what source to start on when the monitor turns on, if it off i believe it goes to whatever source you last had on.
  3. #53
    Oct 2008
    Hi
    I've got a 5 wired lilliput and I've got a problem.
    The touch pannel hast broken so I decided to change the 5 wired for a 4 wired, I put it in the small connector, JP2, but doesn't work. The 5 wired gone in the cable.
    Why? I can't put a 4 wired one in this conector? What's this connector for?
  4. #54
    Aug 2012
    Hello everybody.
    I just bought a lilliput 7" touchscreen.
    But I dont know if it is a 250 nit or 450 nit.
    I've read the first post, but my screen (with removed bezel) looks like the one above in this picture) I know it's 60 pin connector, but it is an 250 or 450 nit screen?
    http://www.mo-co-so.com/v/~photos/66...t/50-vs-60.jpg
    Oct 2012
    The links for the drivers listed on here do not work,
    been looking for a few weeks,
    Need drivers for windows 7/8 64bit, that are actually HID compliant, and dont make my computer think the touchscreen is a mouse.
    Any help?
  6. #56
    Jun 2012
    Quote Originally Posted by Toastoncheese View Post
    Any help?
    I am looking for the same thing. Please post if you find anything.
  7. #57
    Jun 2012
    For anyone trying to get a Lilliput 629GL-70NP/C/T to work on Windows 8 I have had success with driver posted in post #94 at http://www.eightforums.com/tablet-to...-mouse-10.html. They may work with other Lilliput monitors.
  8. #58
    Oct 2007
    S-Petersburg, Russia
    Quote Originally Posted by iVVTi View Post
    Hi, all members. I bought the lilliput 669gl. Who can know, remove blue background screen when signal lost? I can't find it option at menu settings. It really can remove?
    I have a same wish and I made an attempt to understand firmware after its downloading. As I know 6D register of RTD2662 is responsible for background color, but I couldn't find the right place in file... ((
  9. #59
    Apr 2011
    Dimmable?
    Is there any option to allow this screen to dim when the headlights/parklights are turned on? Or at least is it simple to dim it manually?
    Oct 2015
    Damn this threads a bit old! Just chiming in that I bought one of these a few weeks back that has the Lilliput 669GL-70NP/C/T built into it:-
    http://lilliputdirect.com/lilliput-o...n-hdmi-monitor
    The frame is similar to the ByByte (although I couldn't actually get one of those!) and works like a charm using an ODROID with KODI installed.
  1. Lilliput 669GL 7" vs. Xenarc 1020TSV 10.2" (or 8" model)
    By doncarbone in forum MP3Car Products - store.mp3car.com
    Last Post: 11-01-2010, 10:47 PM
  2. Wanted, plastic buttons for Lilliput 619
    By Cret in forum Classifieds
    Last Post: 02-11-2009, 07:10 AM
  3. Wanted : VGA ribboncable for Lilliput 619GL-70NP/C/T
    By gyro in forum Classified Archive
    Last Post: 08-16-2005, 03:31 PM
  4. Wanted 7" Lilliput VGA
    By romeov in forum Classified Archive
    Last Post: 06-30-2005, 09:49 PM
  5. Wanted: Lilliput 8" Housing, case
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 03-13-2005, 11:27 AM
